Zone 2
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Posted on Apr 28, 2013
SOURCE: Yamaha RX- V 663 - unable to change volume on Zone 2
Page 111:
PROBLEM: Zone 2 speaker settings are not available in "SET MENU".
CAUSE: "EXTRA SP ASSIGN" is set to a setting other than "ZONE2".
REMEDY: Set "EXTRA SP ASSIGN" to "ZONE2".
See Page 85
Posted on Mar 13, 2010
Testimonial: "Hi it certainly pointed me in the right direction. Thank you. A few more steps would have been useful and page number suggestion was not correct p33."
SOURCE: Zone 2 Vol Fix
Try this:
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX"
1. Press "Amp" button (right side of remote - 1/3 way down)
2. Press "Menu" button (center of remote - 1/2 way down)
3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver
4. Press "Enter" button (green letters)
5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver
6. Press "Enter" button (green letters)
7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver
8. Navigate from there
Hope it helps. It worked for us.
Posted on Aug 04, 2008
SOURCE: volume fix problem
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Good Luck! This worked for me.
SOURCE: zone 2 volume control
Sounds like the Zone 2 amp was set to external, see below for instructions on
setting it back up.
How do I setup Zone 2 on the RX-V661 Using the internal
power amp.
Setting the RX-V661 remote control to operate Zone 2
1.
Using a ballpoint pen or similar object and press the Code set
button.
The Transmit indicator on the remote should flash twice.
2. Using the
numerical key pad on the remote and key in 9992, the
Transmit indicator
should flash.
You will now need to assign the receivers internal amp for
Zone 2.
1. Set the remote control selector to AMP. Selector is on side of remote.
2. Press the
Set Menu Button.
3. Arrow down to Manual Setup.
4. Press the Enter
button.
5. Arrow to the Sound Menu option and press Enter.
6. In the
Sound Menu arrow to Speaker Set and press Enter.
7. Arrow to the EXTRA SP
ASSIGN and select ZONE2. This may require using LEFT or RIGHT arrow.
8. Press the Return button to exit out and return
to the Manual
Setup.
Posted on May 24, 2009
SOURCE: Yamaha RXV661 Receiver has Zone 2 Vol Fix error message
i have the same problem. i have a rx-v661. i goto the zone 2 settings and try to change the volume and it says VOL FIX. I cannot hear anything out of zone 2. It takes the current volume that is in zone 2, but i cannot hear anything. it has been working fine for at least a year.
Posted on Jun 27, 2009
