I tried Windows media player and i'd put the songs onto a playlist and add to sync list and clic start it would freeze for a momment then say theres a connection Error
Just do it manually go to your computer and then open the sansa mp3 player icon continue until you see a folder where it says music and then just drag and drop it in there
Once you plug in the MP3 player, open Windows Media Player and you should see it listed as a device. Right-click the device in the left-hand column of the Windows Media Player and click 'Set Up Sync'. Put a check in the 'Sync this device automatically' checkbox and then add one of your existing playlists that are in the list on the left side to the right side by selecting the list and clicking the 'Add' button, located between the two lists. If you don't have a playlist, you'll need to create one.
Once you have all the songs you want to add to your mp3 player added to your playlist, you can then select the device again, and click the 'Sync' tab at the upper, right-hand corner of your Windows Media Player and then click 'Start Sync' to sync the playlist with your mp3 player.
Any songs you want to add or remove from your device, you simply add or remove them from your playlist and then sync it again.
be sure that you have already saved a list of song on your playlist. and for the pdf also make sure that there was a file that save on that location...
Assuming the player is charged. (For charging always connect directly to the computer, not through a reader or hub).
When buttons on the player do not react, reset the player:
Disconnect the player from the computer.
See that the HOLD button is not engaged.
Gently push the RESET button on the rear side: use a narrow pointed
object, like a paperclip.
Did synchronization of the songs in Windows Media Player fail ?
For transferring songs, check in Windows Media Player:
1. The player is detected in Windows Media Player 10 or higher.
2. Setup the Library / Add to Library: add the location of songs you want to transfer in the library.
3. Create Playlist; give the list a name and put songs in a playlist
4. Sync Playlist: transfer the list of songs onto the player and wait for the message until you're allowed to disconnect.
On the MP610 you could use either Windows Media Player 11 or Coby Media Manager for transfers of songs.
Next steps are important for adding files onto the player:
1. The player should be detected in the software for transfers, when connecting the USB cable.
2. Setup your library in the software (Add to library): There has to be a list of folders in the software manager, where your music is located on the computer.
3. Create a playlist in the software: make a list of songs, you want to transfer onto your player
4. Sync the playlist onto the player.
When needing more help, just add text in this reply.
Creating Playlist To create a playlist for Windows Media Player, follow these steps: 1. Launch Windows Media Player. 2. Clear the List pane by clicking the Clear List pane button. 3. Click the arrow below the Library Tab then select Create Playlist. 4. Type in the name of your Playlist. Loading Content 14 5. Click Songs from Library then drag them from the Details pane to the List Pane. 6. To rearrange the songs, drag them up or down in the List pane. 7. Click Save Playlist. Transferring Playlists To transfer playlists to your Sansa player, follow these steps: 1. Connect your Sansa player to the computer. 2. Select Sync digital media files to this devices using Windows Media Player on initial connection. 3. Right-click on Your Sansa Player, then select Set Up Sync. Loading Content 15 4. Select Personal Playlists from the drop down menu on the left pane. 5. Highlight the playlists you want to transfer to your Sansa player, click Add, then Finish. 6. Synchronization will start as soon as you click Finish. To see the Sync progress, click on Sync Results.
There is another way but that is called Favorites. First go to settings on the player and enable advance then go to one of your songs and press the select button then it will give you an option that says add to favorites? choose the check mark to add that songs to your playlist. Also there is a way to add playlist using windows media player. The steps given would be for windows media player 10. First click on the Library Tab thecn click on the arrow for the Now Playing List choose New List then Playlist, now add songs to your newly created playlist by dragging them to the drag items here window after you have choosen all the songs you like click on Now Playing List and choose Save Playlist As.. After saving the playlist change the settings of the player to Autodetect and connect the player to the computer. Now wait for it to be detected by the computer and click on SYNC tab on the windows media player software. There are two windows the left is where you will choose the playlist the right your mp3 player. Choose the playlist that you have created and click on START SYNC now it will be transferring the playlist to your mp3 player just go to Music then Playlist. Hope this helps :D
try these methods
**Drag and Drop** Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder, available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player. --**Windows Media Player**-- If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
