I tried to charge the light bulb at the top compartment. I use a meter to test the power of light bulb plug and accidentally short the circuit. As a result the fresh food side has no power. Control board has no power. Freezer side is still running. What is the problem and what parts I need to replace. Thanks!
SOURCE: Problem with fresh food side of my refrigerator freezer
The bulbs dim glow is a worry, sounds like not enough voltage is getting there. If you are comfortable with a multimeter, check what the voltage is at the bulb socket. If you have a low voltage issue due to say the transformer not working properly then the fan will also have low voltage (or no voltage). No power, no fan, no cooling. I'd suspect there are voltage issues with that transformer, especially since it's a 240 VAC model. A transformer typically steps down the 240 volts to 120 volts for light bulbs and maybe even the fans (or the whole refer). The repair man may be correct in that the transformer is built in to a circuit board but it COULD be a stand alone transformer.
SOURCE: GE side by side not very cold on fresh food side
there is one of two thing that could be going wrong here ; you may have a bad evap fan mtr and control board or yourr damper is not opening properly. i would say you have the later of the two due to the fact the rf is still making ice. one thing that causes this issue is too much weight in the door causing the door to lean and not trigger in door light switch or the switch itself is damaged. the door hinge and camm assembly can be adjusted from the bottow using a standard socket set
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
SOURCE: freezer is not freezing,fresh food is not cold
you have a bad defrost timer or a heatting element.mif there is ice on the rear wall you will have to empty it and remove all shelves, pull the cover and you will see the heating element. it will be in a glass tube. you can see if its burned into, look for blackness inside the glass tube. when you install the new one be sure to put it so water wont run inside the tube, or it will burn out right away. good luck you can do this sawdust46
SOURCE: Freezer is cold, main food compartment is warm
the evap fan probably stopped working because of the shorted defrost thermostat. if you remove the freezer drawer you will probably see frost build-up on the back wall. what you need to do is remove the back wall and manually defrost the coil with a hair dryer. have some towels handy. once the ice is melted you will need to replace the thermostat or this will happen again. you should buy a new thermostat before the repair so you know what you're looking for. hope this helps
SOURCE: Freezer side cold fresh side not GE GSH22KGMD
Find the return air It can't come in if it can't get out. also if you were checking it with the freezer door open you will not feel the air. Just in case i have done that myself. if all air ducts are open and it's getting o I should be 20 in fresh food with the control on 9.
