20 Most Recent
Frigidaire Model: PHSC39EHSS Questions & Answers
Ice maker not working properly
Hey, I would check water filter if it has one and the water line to water valve at the back of refrigerator. I'm thinking dirt or something when they work on water problem in other unit.
Frigidaire...
Answered
on Feb 07, 2018
Flashes e f code
This is a combination of problems. I have a Kenmore Elite labeled Frigidaire model 253.44513601. If you are reading this you are aware that Kemore/Frigidaire refer's are JUNK.
I have went through TWO Kenomre Elites since 2001. My lateset Fridge (bought January 2007) suffered the "E F" code.
At first I replaced the Evaporator Fan (behind freezer compartment.) This did NOT solve the problem. I then bought a new control board located under the freezer. (take off toe plate, and removes screw, the board slides out and is connected by 3 wire harnesses.)
My fridge is now running, but it has yet to get "cool." This maybe because the User Interface needs to match the control board. Not sure yet, but I will keep posted.
Frigidaire...
Answered
on Jul 18, 2009
Instructions to remove and install water actuator #241685704
getting access to the actuator. this is the procedure;
turn off the power
Remove the drain tray it just snaps out. remove the 3 screws behind the tray. carefully lift the panel up and out. There is a short control wire connecting the panel to the frig so be careful. remove the water hose from the outlet hole and remove the ice and water module.
its very easy
The drip tray will just slide out and then you will see the screws that hold the trim in place.
to get more complete details just click the link directly and get the proper diagrams
http://appliancejunk.com/forums/index.php?topic=282.0
if you have not had the fridge repair yet here is how to get in to the dispenser to get the actuator.
Feel or look along the bottom edge of the trim on the dispenser and you will see two slots.
Use a flat blade screwdriver to pry the bottom off.
Then slide the trim up and lift it off this will give you access to the screws to replace the actuator.
Here is a place to get Frigidaire parts
please do rate the solution.thank you for using fixya.keep updated.thanks.
Frigidaire...
Answered
on May 24, 2009
