How to View or Change Your Wireless Network Password
Symptoms:
You have lost or forgotten the password to your wireless network
You have lost or forgotten the password for the router, access point or other network device
You left the default password or used a weak password and someone has hijacked your network
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
Launch your Internet browser and type http://www.routerlogin.net in or http://192.168.1.1 or http://192.168.0.1 the address field for your browser. Enter the router's username and password.
The default username is admin, the default password is password.
From the left-hand navigation menu of the Router administration interface, select Set Up > Wireless Settings
Note: On some routers this option will be under BASIC > Wireless.
From the center screen, you find the current wireless security settings under the Security Options heading.
If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Read more about Securing your Wireless Network.
If you cannot log into your router:
- If you were routed to the NETGEAR website or getting the "Page cannot be displayed" message when trying to login to router, make sure you are connected to the NETGEAR router. Check your wired connection and make sure cable is securely plugged in and LED is on. If wireless adapter is on, make sure you are NOT connected on a different wireless network.
- Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default access information to reconfigure your router settings. NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
See the following articles for more information:
Secure Your Wireless Network: WPA/WPA2 (Recommended)
Reset and Restore a NETGEAR device to Factory Default Settings
Default Password for NETGEAR devices
SOURCE: Cannot Set Password on DI524 Wireless Router
Alright, it was a dumb thing to do....just make sure you use internet explorer...It works in there...don't ask why lol....I have no idea :D
SOURCE: How to create a security enable router?
Firstly, confirm that your ISP connection for email and internet is working correctly. Then connect the router to the ISP using the ADSL plug, and to your computer using the ethernet connection. It is best to set up your router using a wired connection to your computer. Once set up, you can connect your computer using WiFi. Have your ISP username and password handy.
There are two steps to secure your router:
1. Change your ADMIN password. Using a web browser like Intenet Explorer, type in the address, http://10.1.1.1. This should take you to a sign-on screen. Username is "admin", and password is set at the factory as "admin". You should now be logged in to your router. Go to the TOOLS tab, and change your admin password. NOTE THIS DOWN FOR FUTURE REFERENCE.
2. Secure the wireless part of the network: Go to the HOME tab, and select either WEP security (good) or WPA security (better, but some devices like printers don't like this).
For WEP you will need to enter a 10-digit WEP key. Numerals will do, or you can use hexadecimal (base 16) notation if you know this. Numerals will do and are no less secure. NOTE THIS DOWN in a secure place. Click the "APPLY" button.
For the WPA alternative, you should select the "Pre-shared Key" radio button, and code in your WPA password in the "PSK String" field. This can be a word and or numerals. I don't think spaces or other characters are allowed. NOTE THIS DOWN in a secure place. Click the "APPLY" button.
That's IT!! You've changed the admin password and secured the wireless part of the network.
You will then need to code the WEP or WPA password into the devices like printers and computers that you want to connect to the WiFi. For Vista computers, right click on the network icon in the tray (two little computers overlapping) and select "Connect to a network". Enter the WEP or WPA password when you see SSID "default" or your SSID if you've changed it. Most printers have a connection wizard.
There is a further enhancement if you are really paranoid: change the SSID and turn off the SSID broadcast. Go to the manual at:
ftp://files.dlink.com.au/products/DSL-G604T-GenII/Manuals/DSL-G604T_GenII_Manual_v1.11.pdf
if you want further details. Good luck with your secure network.
SOURCE: how to secure zyxel 600 wireless network
My nissan p 11 swithces off when in motion. plz asstst
SOURCE: I can't remember the password for my router. I
hi
In your case you have to go to your service provider for more free technical you can visit---http://robs-tech.blogspot.com/2009/06/free-solution-regarding-computer.html
