Somehow after I had been messing with the vcr remote to do some recording, I can only change channels on the tv when the vcr is on and when I am using the vcr remote. It's like the vcr remote has taken over the channel button. When the vcr is off, the only thing that works on the tv remote is the the volume and input buttons. I've been messing with the split screen trying to get it it work...when I hit split screen on my Tv remote, I can get the Tv remote channels to work. But I don't want to have to watch in split screen. Does anybody know what sequence of buttons I need to press to get it back to normal? I've tried the video/tv button on the vcr remote.
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
SOURCE: Insignia IS-LCDTV32 32" Wont let me change channels or go to menu
there is a problwm wit hyour mainboard you can buy one on ebay for about $80 and to remove just take off back panel and unplug about 5 wires and remove 2-3 screws on the left side / the same side that your power ch+/- ect is on. and swap out.
please rate my answer it is much apreceated
SOURCE: Insignia TV is acting wierd
the problem lies in themain board in the tv. you can buy one from ebay for around $80 used. its not to bad to replace either. just remove the back panel the main board it the tin/ metal wit hthe ciruit board in it on the left side same side as the power botton just unplug the 5-7 wires and unscrew the 2-3 screws and carfully side that board out and replace with a new workign one and put back together and you should be good to go.
SOURCE: My Olevia TV will not change channels using the remote or buttons
First thing, check batteries in remote, next make sure there are no obstructions between your remote and your tv. i would then call olevia tech support and describe your problem. sounds like the remote sensor has failed. usually covered under warranty. check with olevia to see if they have a factory wide problem or issue with remotes. persistance pays off in this case so just keep on top of tech support. hope this helps, john.
SOURCE: Panasonic remote and volume/channel buttons do not work
try unplugging while the TV is still on and plug it back after 5 mins and check. it should work.
Mine did. I know this may be a crude method, but it worked.
