HP Compaq Presario V5000T Notebook Logo
Posted on May 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DV2002 Tu lid switch location - HP Compaq Presario V5000T Notebook
Ben Darden
Level 3:
  • Master 984 Answers
  • Posted on May 29, 2012
Ben Darden
Master
Level 3:
Answers
984
Questions
0
Helped
313709
Points
3004
Have you looked for service manual at HP support website already? It could have pictures showing the location. CLICK HERE
Some newer models don't have a visible switch. Instead they use a magnet inside the lid that triggers the switch when closed. That can very well be in the palm rest or anywhere else.
Water is not draining out
sounds like the saftey switch located where the lid closes, you will find attached to the inside of the lid a pin or tab that when the lid closes allows the washing machine to turn on and turns off when the lid is opened, to test if the switch is not working, with the lid open take a pencile or pen and push down on the switch which is located just oppsite where the tab or pin on lid comes in contact with the machine
My problem is the washer won't drain or spin. i saw the solutions and sounds like my problem is the lid switch but it leads to another problem. what and where is the lid switch.
where the lid switch is on the top-back of the washer near the water inlet. you must open the cover. lid position switch associated with the hinge lid-open lid. you must open the screw from the cover. Pull up on the cover, after being released you can find where the lid switch, the location was near the water level sensor. can be used to manually switch, or a light sensor, located under the cover of your washing machine. Hopefully help
2helpful
Washer fills up but won't start cycle we have to slam door down a few time's to start cycle
The most common cause of the symptoms you describe is a lid switch malfunction.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30. Prices differ between sites so shop and compare.
If you have questions, need additional assistance, please post back with your model number (located on a nameplate along the wash tub opening under the washer lid), so I can provide you with better assistance. I hope this helps you.
NOTE: Slamming the washer lid is not recommended as this can contribute to premature failure of the lid switch. This is the number ONE cause of broken lid switches.
5helpful
Toshiba model A205 S5804 ; where is the lid switch
No Lid Switch...
Magnetics Are Used To Turn Off/On LCD Bulb When Lid Opens and Closes... One Located In THe Screen And Sensor Located In The Laptop Palmrest..
1helpful
Lid Switch
hithanks for the question The lid switch is located under top on right side if you open the lid you will see a small plastic plunger on the lid this plunger is what activates the lid switch Thanks for your question hope thisanswers your question The appliance doc
For weeks now I've had to slam the lid on my washer to get it to work. Now nothing! The same thing happened to my dryer...close the lid and nothing. It wasn't even a year old and someone had to come out...
ck lid screws especially on newer models on these the lid switch is located left rear corner just behind lid hinge if switch is on right side close lid slowly and listen for click if none heard try pressing down on lid at switch location if washer starts replace switch if switch lever broke change switch..on other type switch lower lid slowly and listen for click if none heard and hinge screws ok raise lid and push lid hinge toward back slightly and try again still no click raise console switch is on left and just snaps in place
Fills, then nothing
This is a symptom of a loose or defective lid switch. If you open and close the washer lid, you should hear the "clicking" sound of the lid switch as it is activated. If you do not hear anything, check to make the switch has not come loose. Sometimes a simple tightening of the mounting screws will re-align the switch to its proper location. If the switch is broken and does not function, click on the following link for advice on how to replace the lid switch for a Whirlpool washer.
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
Most lid switches are located on the right hand side of the wash tub opening under the rim of the external case. There will be a small hole where a plastic piece on the lid (called a lid strike) pushes down on a contact. Make sure the lid strike is not broken off. This will also cause the same symptoms.
On other models, the lid switch is located on the left-hand side in the by the hinge of the lid under the washer casing rim. This switch is out of view and is activated by a rod on the lid switch hinge. Sometimes the rod requires adjusting to correct a simple contact problem. NOTE: Your washer will not have the small opening on the right-hand side of the wash tub rim if equipped with this type of lid switch).
Please post back if you require further assistance. I hope this helps you.
3helpful
Machine stops mid cycle and does not drain. machine is whirlpool AWM6100/S
If your symptoms are:
1. Washer fills
2. Washer agitates.
3. When washer gets to spin cycle, it stops.
This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plastic piece called a “lid strike” on the lid itself. Make sure the lid strike is not broken off. This will keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid hinge. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and maybe agitate, but will not start the rinse or drain cycles. If you diagnose it and wish to attempt the repair yourself, the switch costs about $35 and can usually be found at either repairclinic.com, or searspartsdirect.com. Just type in your COMPLETE model number (located around the lid opening) in the Search menu.
I hope you find this helpful. If you have any questions please let me know by posting comments.
It fills up with but completely stops after it
If your washer fills, agitates, but won't spin out to rinse, this is usually a symptom of a bad lid switch. The switch is usually located on the right hand side of the washer tub opening around the rim where the lid seats. There is also a plastic plunger on the lid that will push down on the switch when closed to make contact. On some models, the lid switch is located on the left hand side of the lid in the rear. It is controlled by an armature on the hinge of the lid closing the switch contacts. Check the switch by opening and closing the lid. If you do not hear a distinctive "clicking" sound of the lid switch, the switch isn't working and/or the plunger may be broken off. If you can provide your exact model number (located under the lid of the washer along the rear rim of the tub opening) I can tell you which type of switch you have and the part number. Let me know if this is helpful. This is a very common problem with this model washer and a simple fix.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
