Noisy sound and white particles are comming with flash light
I have purchase a Canon S5 IS camera before three month, past one week i m observing that, when flash light is get focus during photography, some noisy sound and white particles are coming, is it a problem or some setting in camera ?
Re: noisy sound and white particles are comming with...
The noisy sound is not a good sign as it means that there's something wrong with the lens alignment mechanism. I suggest you take it for a service since the cam is only 3 months old and still under warrany
Those are dust particles in the air reflecting the flash from the camera. This happens on point and shoot cameras because the flash is almost in line with the lens.
The flash circuit is defective. As it's only a couple weeks old, recommend just exchanging it for another from your place of purchase. You shouldn't be attempting repair while its under warranty.
the image is all white or has lines through it.Definitely sounds like a repair issue, and has been a previous problem
with the camera in the past. There is a defect in the sensor of the
camera, and happens quite frequently in this model. I would try and
contact Canon about it, and see if they'll repair it for free. If not,
its probably going to cost more than the camera is worth to repair it.
Good luck, and if anything you can upgrade to the S5, a good camera
without the sensor issue.
I have the same problem.. however I did leave my camera in my car for the past couple of weeks.. and it has gotten pretty hot in there.. I'm guessing the heat busted my flash..
When shooting with flash in a location where there are many suspended particles, such as in a dusty area or on a snowy day, the image may contain white circles as shown in the picture below.
Why does this happen?
If the flash fires when a suspended particle floats right in front of the lens, the reflection of the flash from the particle appears more intensely than that of the subject, as the particle is much closer to the lens than the subject.
Therefore, the reflection of the flash turns out in the image and causes an effect such as that shown in the sample image above.
The closer the lens and strobe are located, allowing suspended particles to be exposed to more light, the more frequently this effect can occur.
How can I avoid this effect?
Ideally, it is best to shoot in locations where there are very few suspended particles. If not, you can use following method to prevent this effect.
a) Avoid using flash by lighting the area as much as possible.
b) If your camera has a zoom function, shoot at a wide angle.
c) If you can attach an external flash, use the external flash to distance the flash from the lens.
