Troubleshooting & Support
Hot Topics:
- lens error...
- canon sd600
- memory card...
- sdhc
- driver
- card locked
- set date time...
- video
- won turn
- lens error
- reset lens...
- download...
- memory card...
- memory card...
- battery door...
- sdhc memory...
- sd60
- update firmware
- upload
- broken LCD
- manual
- card locked...
- mode switch
- stuck movie...
- battery charge
- lens stuck open
- format
- restart
- webcam
- switch broken
- View All »
Problems & Solutions
how to delete protected images
If you want to delete everything on the card, the easiest way is to format the card. This will wipe out all images (and any other data as...
I have a computer without
Try this web sight click at the bottom were it says drivers and software then select your OS.. all downloads available for this product...
it has a new memory
I am assuming you are talking about an SD memory card. There are two reasons why your memory card may not be working properly. ...
camera wont recognize 8GB mem
The SD600 works with MMC and SD cards. Your 8GB card is an SDHC card. While it fits into the slot, it is electronically incompatible and...
My camera says, Lens Error,
A lens error can be caused by physical damage to the mechanism that controls the lens, or debris that is interfering with the operation of...
ma canon sd600 comes up ''lens error...
Hello The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that...
Canon Powershot Lens Error Restart
Work with a 1 GB
The SD600 works with MMC and SD cards. Your new 8GB card is actually an SDHC card. While it fits into the slot, it is electronically...
i turned the camera on
That's a great little camera, what you probably have is dirt in the gears or they may have just gotten jammed. A great camera though,...
the lens is stuck out
This is a very common problem, deb-ri builds up over a period of time and jams the lens housing. Get a can of compressed air attach the...
can sdhc memory card work
A Canon SD 1300 IS camera can handle the following memory cards SD/SDHC/SDXC Memory Card, MultiMediaCard, MMC Plus Card, HC MMC Plus Card...
I get a memory card error when I turn my camera
Yes. The SD600 works with MMC and SD cards, not SDHC cards.
my camera says memory card error
Hello OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card...
Hi, I borught one canon
Remove the card ..and batteries..and insert the batteries again ..If it works fine without the card ..it means that the card is either not...
My Camera is saying, "Lens Error, restart...
Try removing the battery for an hour or so to make the camera restore the default settings?
Unsolved Problems
I have a Canon PowerShot SD600 Digital Camera and...
I've taken the physical button off and have pressed it using a toothpick to really get to the actual button, but...
Cannon sd600 video has no audio
My cannon sd600 was working fine and now when I record a video with it the video has no audio on playback. Any...
it will no longer show image in screen during...
when i turn the camera on, I can see an image in the lcd screen... after 1 second, the screen goes blank. it's...
Loved my camera until it suddenly stopped turning...
Loved my camera until it suddenly stopped turning on. Charge the battery. Two days after I flew a plane I discovered the...
my photos are white
when i review a photo that I've taken it is really light or almost white
how to make a continuous shots in a canon
how to make a continuous shots in a canon powershot sd600 model
My camera says "busy" with a hand and a...
My camera says "busy" with a hand and a line through it. It can still take and upload pictures...but you...
I tried new battery, but camera will not power on.
I tried new battery, but camera will not power on. Any suggestions on what to do?
I get a busy signal
I get a busy signal that won't go away and won't delete pictures
Manuals & Guides
TopDo you have a manual for Canon PowerShot SD600 Digital Camera? - Upload it to FixYa!
Upload a manual for Canon PowerShot SD600 Digital Camera
Specifications
TopKey Features
Full Product Name:Canon PowerShot SD600 Digital Camera
Camera Type:Compact
Image Sensor Type:CCD
Resolution:6.2 Megapixel
Optical Zoom:3x
Lens
Focus Type:Autofocus
Focal Length:5.8 - 17.4 mm
Interchangeable Lens:Without Interchangeable Lens
35mm Zoom Lens:35 - 105 mm
Digital Zoom:4x
Macro Focus Range:1.2 - 19.2 in. (w) / 12 - 19.2 in. (t)
Focus Range:11.81 in. to Infinity (w)
Image Quality
Camera Resolution:6.2 Megapixel
Image Resolutions:1600 x 1200
Image Resolutions:640 x 480
Image Resolutions:2272 x 1704
Image Resolutions:2816 x 2112
Video
Video Resolutions:640 x 480 (VGA)
Video Resolutions:320 x 240 (QVGA)
Video Resolutions:160 x 120
Video Speed:30 fps
Video Format:AVI
Video Format:Motion JPEG
Exposure Control
Shutter Speed:15 - 1/1500 sec
Frames per Second:2.1 Frames
Aperture Range:f2.8/f4.9 (w/t)
White Balance:Manual
White Balance:Auto
White Balance:Daylight / Sunny (Preset)
White Balance:Fluorescent (Preset)
White Balance:Tungsten (Preset)
White Balance:Cloudy (Preset)
Storage
Memory Type:SD Card
Memory Type:MMC Card
Compression Modes:Fine
Compression Modes:Normal
Compression Modes:SuperFine
Compression Type:JPEG
Compression Type:DPOF 1.1
Compression Type:EXIF 2.2
Flash
ISO Speeds:200
ISO Speeds:100
ISO Speeds:400
ISO Speeds:Auto
ISO Speeds:800
ISO Speeds:80
Flash Type:Built-in
Flash Functions:Flash Off
Flash Functions:Auto Flash
Flash Functions:Fill-in Flash
Flash Functions:Red-eye Reduction Flash
Flash Functions:Slow Sync
Viewfinder / Display
Viewfinder:Optical
LCD Panel:With LCD Panel
LCD Panel Size:2.5 in.
LCD Screen Resolution:173,000 pixels
LCD Protected Position:Without LCD Protected Position
Interfaces
Video Interface:Video Out
Interface Type:USB 2.0
Power Supply
Battery Type:Proprietary Lithium
Battery Life:160 Images
Included Features
Self Timer:10 Sec.
Self Timer:2 Sec.
Tripod Mount:With Tripod Mount
Dimensions
Depth:0.85 in.
Width:3.39 in.
Weight:0.31 lb.
Warranty
Warranty:1 Year
What's your problem?
Fix-O-Meter
88,403
88,403 people have viewed this product
- 693 people asked about this product.
- 405 people found solutions for this product.
- 16 people have added this product.
Have a good...
Digital Camera...
How to Unlock...
