Yesterday, i made the las update then i started an online match and then the console turn off, no red light, no yellow light, then i disconnected from the ac power and leave it, and then today i connected and they wont turn on anymore. no sound of nothing no lights nothing....PLEASE HELP MEE!!!!
Hi Juan,
this is all i could find on the internet on what it might be.
Power supply is probably fried, but just try holding your finger down on the eject button and then flip the power switch back to on postion, it might help because this holding sequence re-boots the system and fixes some things.
or you could try this link to a youtube video,but what ever you try its at your own risk.
What to do when your ps3 won turn on
or see if this one helps you out.
Ps3 wont turn on Google Search
SOURCE: light turns on, light turns yellow, light turns red and blinks.
Your ps3 has overheated. This is the equivilent to the red ring of death for xbox 360. The ps3 problem is called "yellow light of death" this means your ps3 has died due to the console being overheated. The solution to this problem is either getting a new playstation or take it to a shop in the UK and they could help you fix it for a price around £30-£50 GBP.
SOURCE: my ps3 won't release game out of console get yellow light
If you turn your ps3 off in the back, then hold down the eject button while you turn it back on it should come out, your welcome. j/k but it did work on mine.
Testimonial: "i got it out thank you for help!!!"
SOURCE: ps3 yellow light
this is what's known as the yellow light of death. this will need to be professionally repaired in order to work properly. check with sony to see if your unit is still under warranty: https://service1.us.playstation.com/rma.htm?_flowExecutionKey=_c42AAD4C5-D9D7-3A33-625E-9DA8C64771EB_k52930EA4-D8DC-F2F8-7A3D-01F2E5C1A8BA
if your unit is not under warranty, we'd be more than happy to help you with this. we use the same method as sony, we reflow and reball the processors on the board.
you can contact us at 214-222-5788 or [email protected]
SOURCE: My older ps3 is overheating and the yellow light
This is a problem with your fan inside your ps3. it has malfunctioned. Unfortunately it cannot be repaired. it will need to be replaced. if you have warranty contact your insurance company. If you do not have warranty. Call up sony discuss it with them.
hope this has helped you.
have a great day.
Thanks.
SOURCE: I have the 40 gig
Hello there Rick If you have the red
blinking light then you have the RED light of death AKA the RLOD. The light is a warning
sign to let you know something is wrong. I can give you the quick
explanation, There are 2 chips on the motherboard inside the PS3, the
GPU (graphics) and the CPU (brain), when playing the ps3 the solder
heats up and when you finish playing it cools down, over time this
will cause the soldering to crack and the chips to lose connection
with the motherboard and you get the RLOD. WHERE TO GO FROM
HERE Option
1 - Call Sony In warranty the Price
is Free, out of warranty the Price is $150,
the whole process is 4-6 weeks You can call Sony and
they will collect the PS3, repair/replace, and deliver the PS3 back
to you Option
2 - Fix it your Self You can use a PS3 fix
manual to get this fixed easily and at home using household tools you
probably already own. Click
Here For The PS3 Manual which has helped so many people like you. Good luck Best regards
Peter
