After power surge printer is non responsive to power or paper feed buttons with both LED's dimly lit. No carriage movement at all with lid up or down. Power supply checks with 30v on volt meter. Ibook does not recognize device connected. Somthin's fried?
The adapter of the printer is got short and its towards it end.get it repaired to make the use of same adapter if you will keep the printer ON this adaptor will go completely dead due to getting heated.and will become total scrap and you will have to buy a new replacement adaptor worth $20 to make your printer work again.this is a very common problem in this printer of adapter getting short due to power surge,
thanks,
E2-2 No paper (ASF) E3-3 Paper jam E4 No ink E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera Direct Printing E14 The Ink cartridges whose destination are wrong E15 Ink cartridge is not installed E16 - Ink remaining is unknown E16 -E19 Failed to scan head alignment sheet E22 Carriage error E23 Paper feed error E24 Purge unit error E25 ASF(cam) sensor error E26 Internal temperature rise error E27 Waste ink absorber full or platen waste ink absorber full E28 Ink cartridge temperature rise error - E29 EEPROM error E33 Paper feed position error E35 15 USB Host VBUD over current error - USB E37 17 Abnormal motor driver error E40 20 Other hardware error E42 22 Scanner error
160 resetting errors
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button. 2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button. 3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection) 4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.) The number of the Reset button pressing LED Function Remarks 0 time Green Power off 1 time Orange Service pattern print 2 times Green EEPROM print 3 times Orange EEPROM reset 4 times Green Waste ink counter reset See waste ink counter reset procedures below. 5 times Orange Destination setting See Destination setting procedures below. 6 times Green Print head deep cleaning 11 times Orange Button / LCD checking 12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center. Hope this helps. Please rate my response. Thanks. Have a good day.
E9 The connected digital camera / video camera does not support Camera Direct Printing E14 The Ink cartridges whose destination are wrong E15 Ink cartridge is not installed E16 - Ink remaining is unknown E16 -E19 Failed to scan head alignment sheet E22 Carriage error E23 Paper feed error E24 Purge unit error E25 ASF(cam) sensor error E26 Internal temperature rise error E27 Waste ink absorber full or platen waste ink absorber full E28 Ink cartridge temperature rise error - E29 EEPROM error E33 Paper feed position error E35 15 USB Host VBUD over current error - USB E37 17 Abnormal motor driver error E40 20 Other hardware error E42 22 Scanner error 1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button. 2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button. 3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection) 4) When the LED lights in green, press the Stop/Reset button 3 times for Orange EEPROM reset. Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.) The number of the Reset button pressing LED Function Remarks
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
1. Turn the printer off and open the access cover. 2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.) 3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.) 4. Watch the paper as it feeds through and try to determine where the jam is occurring. 5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6. If not, there is probably a feed motor or a gear problem and the printer may require service. 6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. 7. Turn the printer off. 8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers. 9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
First make sure there isn't any thing keeping the carriage from moving freely, the reset as follows: How to clear Error Code Canon printers MP150 MP160 CANNON Printers MP150/MP160 ERROR CODE
E9 The connected digital camera / video camera does not support Camera Direct Printing E14 The Ink cartridges whose destination are wrong E15 Ink cartridge is not installed E16 - Ink remaining is unknown E16 -E19 Failed to scan head alignment sheet E22 Carriage error E23 Paper feed error E24 Purge unit error E25 ASF(cam) sensor error E26 Internal temperature rise error E27 Waste ink absorber full or platen waste ink absorber full E28 Ink cartridge temperature rise error - E29 EEPROM error E33 Paper feed position error E35 15 USB Host VBUD overcurrent error - USB E37 17 Abnormal motor driver error E40 20 Other hardware error E42 22 Scanner error
On step 4, hit the stop/reset button 4 times to clear the waste ink error. How to clear Error Code Canon printers MP150 MP160 CANNON Printers MP150/MP160 ERROR CODE
0 time Green Power off 1 time Orange Service pattern print 2 times Green EEPROM print 3 times Orange EEPROM reset 4 times Green Waste ink counter reset See waste ink counter reset procedures below. 5 times Orange Destination setting See Destination setting procedures below. 6 times Green Print head deep cleaning 11 times Orange Button / LCD checking 12 or more times Returns to a menu selection If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
its a mechanical issue , if your handy you have to open and check the rollers where its connected with some plastic wheels , I fix one before with this issue , what I found is one of the plastic wheels was broken (pulleys with teeth) , hope this helps AJ
Carefully check the paper feed track to ensure there is no debris stuck- only needs a crumb to do it.
Take a stack of paper- knock it up- that is with it in your hand knock the ends together so the that all feed straight.
Then try. - no Go?
Get a piece thicker paper/card- and try a paper feed with this single sheet.
Sill no go?
Try to find out how to 'reset' your printer
This may mean if you have several buttons on the machine- with the machine off- hold the buttons down then switch the machine on and keep the button down until it has stopped initializing.
Still in trouble?
Take a look at www.fixyourownprinter.com
