TV periodically flicks off for a few seconds then back on. This comes and goes. Won't do it for days, and then does it every 10 minutes or so.
SOURCE: tv 62527 light goes off when after a few seconds when turned on
This is generally a Power Supply problem, usually the SMPS so it's replacement or repair.
SOURCE: Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
SOURCE: mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
SOURCE: My TV Screen turns green or blue after 10 minutes of the tv on
You have a chip that is overheating due to heatsink coumpound being dried up. You need to find that chip and heatsink and apply new compound to both parts.
SOURCE: I have a Mitsubishi WS 55805 which is around 10
No parts are needed. You need to resolder the DY connectors on all the yokes.
