20 Most Recent Olevia LT42HVi 42 in. LCD Television Questions & Answers
The Samsung Galaxy Tab 3 7.0 (SM-T21XX) does not support MHL. The Tab 3 8.0 does support MHL.
The manual for the Tab 3 7.0 is available on the product page: https://www.samsung.com/us/support/owners/product/galaxy-tab-3-7-0-wi-fi . The only TV feature listed is using Galaxy Tab 3 7.0 as a remote control for your television. You need to accept the Samsung terms of use to download the manual (expand the section on languages).
I wish that I had better news for you.
Olevia LT42HVi... | Answered on Feb 14, 2018
Replace the Tcon board and see if that helps
Olevia LT42HVi... | Answered on Jan 31, 2018
Might need a Digital converter box as it looks like it has no QAM tuner..
Olevia LT42HVi... | Answered on Jan 06, 2018
If you want to spend the mon ey order a replacement main board but on a set that old it may not be worth repairing and the board may be hard to find
Olevia LT42HVi... | Answered on Dec 15, 2017
Probably power supply failure
Olevia LT42HVi... | Answered on May 12, 2017
You may have dying power supply or short circuits, make sure it has 16vdc, 5vdc, and 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Olevia LT42HVi... | Answered on Jan 23, 2017
Check here, it should work out for you - universal-remote-controls.blogspot.com
Olevia LT42HVi... | Answered on Jul 01, 2016
Without a remote control, you can't. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Unlock procedure and to override the password lock to many popular brand TVs are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Olevia LT42HVi... | Answered on Apr 15, 2016
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Olevia LT42HVi... | Answered on Apr 14, 2016
Popping sounds means that there's a discharge inside the tv. Since the HDMI inputs have also failed my guess is that the 20 volts power rail from the PSU has problems, most likely caused by failing capacitors. The tv must be opened and that rail checked. This requires some electronics expertise, if you don't have it then it's time to call a repairman - his labor bill will be much higher than the price for the replacement parts.
Olevia LT42HVi... | Answered on Mar 23, 2016
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Olevia LT42HVi... | Answered on Mar 19, 2016
Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Fault to its main board. Short circuited component/s at it.
Olevia LT42HVi... | Answered on Dec 01, 2015
damm i have the same issue except the left side of the screen is far darker than the right. It still works but is very noticable. If you get this resolved please reply back!
Olevia LT42HVi... | Answered on Nov 26, 2015
perhaps you need to set it on channel 3 for the cable to work .. the cable box must be on when doing any searching also
Olevia LT42HVi... | Answered on Aug 26, 2015
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Olevia LT42HVi... | Answered on May 20, 2015
Hi Mike,
If your TV is more than 4 years old cost of repairs will probably be more than a new or refurbished replacement.
Here's something to try:
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
Olevia LT42HVi... | Answered on Apr 25, 2015
Olevia LT42HVi 42 in. LCD Television Logo
522 questions posted
Top Olevia Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Olevia Televison & Video
Most Popular Question
get child lock off without remote
  • Televison & Video
