20 Most Recent Mitsubishi WD-60C9 60" DLP HDTV Questions & Answers
if user manual says yes
http://www.manualslib.com/manual/794631/Mitsubishi-Electric-Wd-60c9.html
then the right cables
Mitsubishi... | Answered on May 12, 2016
HDMI auto is ON. Go to menu settings and turn OFF auto HDMI. That will stop the auto switching. Regards.
Mitsubishi... | Answered on Jan 05, 2016
Hi Olamiposi
Modern Digital TV's are now Computers with a CPU & Memory etc. Prone to various component problems.
But.... the biggest & most likely problem is that the DC voltages are not stable
Caused by Leaky or Bulging Electrolytic Capacitors
Do you have access to a Soldering Iron?
Do you Have Access to an Electronic Components shop?
If you are not a Tech Type....
Take it to a service tech & ask to check Electrolytic Caps.
Most Tec's these days will Just Do A Board Swap. Costing $$$
If you are a tech type and feel like exploring & fixing the problem.
Disconnect The Power
No Internal 25KV voltages to worry about.
There is a shock hazard on AC side of Switchmode Board.
Electro Caps on AC side can hold 110 / 240v
Check Switchmode internal power supply on DC Side for bad Electrolytic Type Capacitors.
The insulated Tin Cans on the PCB
Bulging or leaky Electrolytic Caps cause many failures in modern digital TV's
Good Luck
Switched mode power supply
How to Replace an Electrolytic Capacitor
Mitsubishi... | Answered on Jan 03, 2016
You need to align the optics mechanically. If you changed the dlp chip and its not centered then the chip is not shimmed properly or the reflection mirror behind the lens needs adjustment. You should get a service manual for that chassis and follow the directions. there may be an electronic method but I am not aware of one.
Mitsubishi... | Answered on Oct 02, 2015
Probably a failing power supply
Mitsubishi... | Answered on May 07, 2015
Your repair tech hinted correct. Although the bad connection will likely be in the power supply, it actualy can sit everywhere the power goes. Can be anordinary plug / connector with a little oxidatin, or a dab soldering point. Or perhaps a electrolitic cap, slowely dying.
Let the tech do his job. He has the tools, education and skills to keep your beloved TV alive.
Mitsubishi... | Answered on Apr 01, 2015
new lamp may have gone bad. was this the recommended lamp for the unit. Most Mitsubishi units must have the correct manufacturer recommended lamp installed.
The correct part# for this unit is 915B403001
You may find that lamp at the following web site:
http://www.shopjimmy.com/catalogsearch/result/?q=915b403001
Mitsubishi... | Answered on Feb 16, 2015
Hello, contact Mitsubishi, they are sending out the chip at no charge to repair the problem, but they do not include the labor. if you are handy, there is a video on how to do it, otherwise when you receive the part contact a repairman. If they know what their doing, they should be able to do it there for around $100-$135.....tks
Mitsubishi... | Answered on Sep 15, 2014
first thing on DLP is to check or try Lamp. If that is O.K., Then unplug TV for 30seconds to 1 minute, then plug back in, does TV come on? If not, try disconnecting input sources 1 at a time to see if any of the sources are causing a problem. If all that fails to correct the issue, then most likely fault is the MAIN/DM PCB.
part#: 934C328001 244.11 + 125.00 core
http://www.tvserviceparts.com/cgi-tvserviceparts/sb/productsearch.cgi?storeid=*20aab4584c1a864062e01c3c70e68e24afb3&search_field=934c328001&search_submit.x=21&search_submit.y=13
Mitsubishi has a policy that requires a service technician to call while on site to verify the failure before they will ship the part to the technician.
Mitsubishi... | Answered on Jun 05, 2014
http://www.mitsubishi-tv.com/
Mitsubishi... | Answered on Jun 04, 2014
Mitsubishi WD-60C9 60" DLP HDTV Logo
175 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
put new lamp in 12hrs later red light
  • Televison & Video
