What does the errror code F30 mean?? We have a Model 790-4660 Kenmore electric range. It gives a F-30 error message every time we attempt to program the oven. It goes away after pressing the clear key. What does this message mean?
We are baking at 350 and we just received an F30 error and the oven shut off. can you tell me what this means
No! I haven't found a solution to this problem yet. The range still gives the F-30 error every time we attempt to program the oven. It has done this since the power failure accompanying hurricane Ike that blew through here in September.
I am still searcing for the reason for the F-30 code for free or very low charge. It is not worth $15 for the info alone. Once I find out what is causing the F-30 code, I will contact you again concerning the repair. In the meantime, the top burners still work, We are using them for now.
I would be much more inclined to use your repair services if you did not charge so much up front for mere informational troubleshooting.
our oven just stopped working, completely shut down and when it came back on it won't stop beeping and it displays f30
same problem here
