SOURCE: AVH-P6500DVD
theres a bad connection on the ribbon cable or its broken or cracked.. I hope you can find one with having to purchaqse a screen Good Luck
SOURCE: avh-p5700dvd touch screen
Go to: http://akamaipix.crutchfield.com/Manuals/130/130AVHP570.PDF This manual will give you everything you need for your Pioneer unit.
SOURCE: FACE
You can take a piece of tape or a small peice of paper (matchbook anything) and pin back the little tab in the middle towards the bottom that is pressed when you put the faceplate on or goto circuit city and steal one off the floor model i had the same prob gl
SOURCE: Nothing works on my Pioneer P7500dvd after getting a new ribbon??
I recently opened my unit up and experienced the same problem. What I found is when I took it apart, I had to remove the gray portion that holds the removanle faceplate. It has two tiny screws, one on each side. When I removed them the piece flips up and comes loose except for the ribbon which clips in place with a tiny plastic clip that WILL BREAK if you remove it. You have to basically break it to get it apart. The ribbon is covered by a small silver plate that has two screws. Since the clip breaks, when you put it back together, you have to slip the ribbon in place and find some way to secure it. What I did, is i placed the ribbon back in place and placed a dab of silicon on the broken piece and placed it back in its original position. I then placed a piece of black electrical tape over it to hold it in place. The ribbon needs to be held down tight to work so I took about two inches of black electrical tape and folded it a few times, placed it on top of the broken ribbon clip and placed the metal cover on top of it. Basically when you put the srews back in placed it squeezes down on the tape, clip, silicon and ribbon holding it in place. I turned it back on and it worked. Hope this helps. Dan(Macgyver)
SOURCE: My tv will not get a picture after the system was
There are a few companies now - like Pyle and Farenheit that make digital converter boxes for mobile applications.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
