Sony BRAVIA KDL-46W3000 Television Logo
kevin clerk Posted on Mar 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Television picture has no picture it just displays a multi colored set of lines almost like a plaidlook u can kind of makeout nfaces like they are in the background before this it would get a six inch black line that would move from left to about the center and back
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Mar 05, 2012
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008859
Points
237762
Hello
The T'Con board {Timing Control Board] has damaged. It should be repalced.
I have multi colored lines from top to bottom but still have picture
This is usually the TCON board or ribbon that connects it to the display panel. If it is a LCD and not a plasma set.
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
My ten year old sony plasma tv has vertical herring bone lines no picture just color lines. Is my picture tube gone.
If its 10 years old boards and or parts will likely not be available--average life on Plasma and LCD sets is 3-5 years.
I would retire it--recycle it and buy a new set.
Dell 42" Flat Panel TV....Multi colored lines on screen...twinkling colors
your flat panel set was hit by something causing the pixel lines. from physical force. sorry to tell you this but the display panel has to be replaced. call a service shop for verification.
Picture is doubled and multi-color
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
I own a color TV 29 '' model CM29 FS1 The color display on the screen shows Multi-colors instead of plain Blue. The Multi colors continued to remain on display even when the picture on the TV / DVD comes...
Hi! the problem you have describe denotes that you have a defective positive thermistor. the positive thermistor is the one responsible in turning on the degaussing coil to align the stray color on the picture tube during start-up.
2answers
Problem with my rca projection television
my RCA R52WH74 HDTV IS STARTING TO LOOK BLURRY. ALSOMY SCREEN LOOKS LIKE IT STRETCHING MY TV PROGRAMS....... CAN U GIVE ME A SOLUTION
1helpful
Multi colored vertical lines
Probably you need an optical block, but it would take a tech looking at it to be sure
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
