20 Most Recent Philips 55PP9363 55" Rear Projection HDTV-Ready Television Questions & Answers
POWER BOARDS, IF THERE IS A LED BLINKING...NOTE NIMBER OF BLINKS AND CONTACT PHILIPS TECH SUPPORT
Philips 55PP9363... | Answered on Feb 03, 2014
You can try to Google the model number with "manual" for this older set or try the Philips website---any authorized Philips service center would have direct access to that database.
Philips 55PP9363... | Answered on Dec 02, 2012
Mitsubishi will have a VS, WS model number.
Most will have a date made on the rear and ones after about 1998 have a self check.
If green power light comes on for a few seconds and goes off:
On the front of the set (not the remote) press and hold BOTH THE MENU AND INPUT (input on some models is Device) FOR AT LEAST 5 SECONDS AND RELEASE BOTH.
Power light will blink a 2 digit error code like: 2 blinks, 2 blinks a pause and repeat it several times.
If you have unplugged the set that clears the error code and you will have to plug it in and try to turn on again--then do the check.
Let me know what error code you find and I will tell you what it means--2,2, is the most common one.
Philips 55PP9363... | Answered on Apr 11, 2012
you have a miss aligned convergence. try to aligned it first.
Philips 55PP9363... | Answered on Oct 25, 2011
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Philips 55PP9363... | Answered on May 12, 2011
Could be a couple different things.. clicking sounds like it may be the power supply, or it could be the bulb as well. My suggestion is don't sink money into repair it will be costly and not worth it considering you can purchase a 55" LCD for $650 now with a superior picture quality. Spend about 1.5K and you can get a fantastic one.
Philips 55PP9363... | Answered on Apr 07, 2011
hi, i'm having a similar problem and was wondering if you ever got yours fixed? i've found the FBT, it's located on the bottom right side as you're facing the back of the TV and it has 3 red wires coming out the top. mine, i've noticed, sparks once when the tv is turned on. i can't find a replacement part for under $300. any suggestions?
Philips 55PP9363... | Answered on Feb 01, 2011
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Philips 55PP9363... | Answered on Dec 22, 2010
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dul
Philips 55PP9363... | Answered on Dec 04, 2010
It sound as if you have convergeance errors.
To adjust the convergeance, follow the service manual's instructions as if you don't, the controls are interactive and it will be difficult to complete a reasonable adjustment.
Hope this helps.
Philips 55PP9363... | Answered on Nov 19, 2010
That is not an hdmi cable input that is a vga type connector with the 2 rows of pins.Get the manual out then call "Radio Shack" to get the right connector.
Philips 55PP9363... | Answered on Oct 01, 2010
LOOK at attached photos and if they look anything like yours you have a convergence problem.
Most of the Philips sets use either 2 of the STK-392-120 OR a few use the STK-392-110 (NOT INTERCHANGEABLE PARTS).
WITH SET unplugged and back cover removed they will be on far left board on side by side metal plates with fins (heat sinks).
Set will need to have chassis in "service position" to replace them and I can tell you how.
TOTAL PARTS COST IF PURCHASED ON EBAY will be under 25 dollars total.
If the photos or this information helped you rate this solution as very helpful as I do this here for free.
I can assist you with this repair and most can do it themselves.
SD TECH
Philips 55PP9363... | Answered on Aug 23, 2010
Unplug the tv for fifteen minutes or so.
Philips 55PP9363... | Answered on May 12, 2010
Philips 55PP9363 55" Rear Projection HDTV-Ready Television Logo
71 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
phillips 55in rear projection
  • Televison & Video
