GE JVM1651 Microwave Oven Logo
Stephen Gallagher Posted on Sep 11, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I changed the hood bulb on this model, and I did not unplug the microwave. This caused me to trip a circuit breaker. Upon putting a new light bulb in, I noticed that the light doesn't work. The microwave works fine except for the hood lights and the vent fan now doesn't work. Any ideas? It seems there must be some common part that these two components share that got burnt out.
  • jadugan Nov 02, 2008
    I have the same problem. My husband changed the light bulb and did not unplug the microwave. Now the stove light and fan dosen't work. Everything else works fine. My microwave model is JVM1660.
  • Anonymous Mar 15, 2014
    I have a rvm1426ba hotpoint microwave that the range lights and the hood fan do not work. Ideas?
William Miller
Level 3:
  • GE Master 9,179 Answers
  • Posted on Nov 01, 2006
William Miller
GE Master
Level 3:
Answers
9179
Questions
Helped
4481688
Points
21747
The control circuit board needs to be removed and repaired. We routinely repair these from customers nationwide for $32.50. It sure beats the cost of a new board!
I replaced the light bulb under the unit on my microwave and went to turn it on and it tripped the circuit breaker and smoked the control panel. The only fuse in the unit is still good. Any thoughts?
< - Please let me know your full model number from the tag on the unit and I can can give you the repair information you need.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
GE Microwave Spacemaker2. The toouch screen does not respond
could use a little more detail.
when u have no display screen the solutions are. possible causes * A fuse in your home may be blown or the circuit breaker tripped. A. Replace fuse or reset circuit breaker
* Power surge. A. Unplug the microwave oven, then plug it back in.
* Plug not fully inserted into wall outlet A. Make sure the 3-prong plug on the oven is fully inserted into wall outlet.
* Door not securely closed. A. Open the door and close securely.
Our GE JVM153SH microwave continues to blow the elecctric panel evety 4-6 months. why ?
If the microwave is not on a dedicated circuit, it's just the additional load the microwave is adding to the circuit which is causing the breaker to trip.
1helpful
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
There is no power to the unit at all circuit breaker not tripped
blown fuse-easy fix -find book-it is shown behind service panel
GE JVM1450WA Microwave
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
JVM1190 Surface light and fan will not go on
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
1helpful
GE Microwave Surface Lights
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit. It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line. We regularly repair these nationwide for $32.50. Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
3answers
Fan and Lights do not work
Sorry a bad controller printed circuit board or what GE calls a smart board. I have seen these smart boards as low as 85 bucks, go up to a price of 179.00!
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
