Hi robbimic,
The first thing to check is the firmware of your PSP. You should make sure that your PSP has the latest firmware loaded. Because some games will not work or load up if the latest firmware is not installed or loaded up.
You usually get this error message 80010087 if the UMD drive has errors reading the UMD disc or otherwise the disc is not present or was ejected while in the middle of playing a game or loading a movie. I suggest that you try to testing to see if the problem happens with other UMD discs, if it doesn't then most likely the disc could be damaged or scratched.
Now if you are using a modded PSP then you will get this error if you load a game from the memory stick without having any UMD disc inserted in the drive. Or if the game that you are trying to load requires a higher firmware version installed into the PSP. You will be required to flash a higher modded firmware to fix this error if this is your case.
Hope this helps!
Peace! :)
SOURCE: my psp says error (80010087)
Try these steps:
1 save your data on your psp system to a memory stick
2 reset system to default settings
3 delete old license folder
4 reactivate psp on playstation store
5 try it again
SOURCE: psp
if its M33 custom firmware, goto the Recovery menu. (power it off fully. turn it on, and hold the R button until it appears.)
goto Advanced > Advanced configuration > and enable Execute Boot.bin in UMB/ISO
save that setting, exit out, and now test your game.
i get that same error sometimes. changing that toggled setting fixes it for me. but this only works on M33 custom firmware unfortunately.
downloading and installing custom firmware is another whole post worth though.
well my problem comes from a playstation store game (brain challenge) ipurchased nad my memory card went out re-did everything downloaded again from PSS and received error 80010087 when trying to play the gmae
