On pioneer 1400 cd player
SOURCE: setting clock on my pioneer deh 1400
the radio must be turned off with the ignition key in the on position... then hold the function key for about 3 seconds if it doesnt have the function key try the audio or source button one of them will bring you to a menu, once in that menu use the func key to scroll though options until you see the clock flashing.. use the up down left right keys to adjust these different options...
SOURCE: Need Information on setting clock on Pioneer DEH-P47DH CD Player
I just tried it after researching on other sites. Keep the ignition on and the power to the stereo off. Hold down the function button (on the lower left for the DEH-P47DH) for a few seconts and the arrows will let you adjust the time.
SOURCE: i cant set the clock on my pioneer deh 21001b cd
Adjusting initial settings
1 Press SRC/OFF and hold until the unit
turns off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select one of
the initial settings.
CLOCK SET (clock)—AUX (auxiliary input)
# To return to the previous display, press
DISP/BACK/SCRL.
# To return to the main menu, press and hold
DISP/BACK/SCRL.
# To cancel initial settings, press BAND/ESC.
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select
CLOCK SET in the initial setting menu.
Refer to Adjusting initial settings on this page.
2 Press MULTI-CONTROL to display the
setting mode.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
