Performance Designed Products PDP Aly & AJ Wireless Guitar for PlayStation 2 Logo
Kimberlie Mooney Posted on Jan 09, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the synch button on the receiver of this product
ZJ Limited
Level 3:
  • Master 17,989 Answers
  • Posted on Feb 01, 2012
ZJ Limited
Master
Level 3:
Answers
17989
Questions
0
Helped
14459458
Points
60858
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
How to synch remotes on a Liftmaster 1/2 HP Security + garage Door opener
Click the learn button on the receiver followed by the remote. See e.g. http://www.liftmaster.com/CatalogResourcesV3/en-us/shared/files/tucmanuals/114A4109.pdf
Youtube activate enter code6yzyx5hf
If you are trying to get your YouTube account synched with your TV you need to sign in to your YouTube account on a computer and put the code in to YouTube. I always use my laptop to do this.
Mouse not working
Try unplugging it and replug it if is USB, if wireless you might need new battery or need to re-synch with receiver (there a button on bottom of mouth & receiver, press both to synch them).
My keyboard is not working and I have just put in new batteries. However, the mouse is working fine.
You may need to resynch the keyboard with the receiver. I'm not 100% sure of the procedure for the Kensington PilotBoard - but normally all you need to do is hold down the Connect or Synch button on the receiver (in this case the USB Dongle) until the light begins to flash. Once it's flashing, press and hold the Connect or Synch button on the Keyboard (usually its on the back) until the light on the receiver stops flashing.
My wireless optical mouse lose conection.
You should be able to reestablish connection by pushing and briefly holding the connect button on the receiver until the light begins to flash. Once it's flashing you can push and briefly hold the connect button on the bottom of the mouse. Once they are synched the light on the receiver should turn solid.
My Kensington wireless keyboard (Ci70) just stopped working. I have no idea why. The mouse works just fine. XP Pro SP 3. Have rebooted. Unplugged the USB interface device. Plugged back in. Rebooted....
Replace batteries in keyboard and re-sync the devices
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Synching Mouse or Keyboard with Wireless Optical Desktop trnsp.gif Question My mouse or keyboard doesn't work with my Wireless Optical Desktop (Model Number: 64373). What's wrong and how do I fix this problem? trnsp.gif Answer Your mouse or keyboard has lost its sychronization with the Wireless Optical Desktop, which can occur after changing the batteries, for example.
To synchronize your wireless device with its receiver:
  1. Move the device within three (3) feet of the receiver.
  2. Press the button on the receiver.
    If the receiver has an LED, the light blinks.
  3. Within ten (10) seconds, press the button on the underside of your wireless device.
    If the receiver has an LED, the light glows solidly when synchronization is successful.
Early production units of some wireless devices may require repeating the above instructions two or three times.
Timing, distance, and objects impeding the wireless signal may influence your success. While usually unnecessary, some customers have reported better results by:
  • Holding the wireless device very close, within three (3) inches of the receiver.
  • Entirely ignoring the receiver's light.
  • Simultaneously holding the buttons on both the receiver and the device for from ten (10) to twenty (20) seconds.
1helpful
How do I synch the mouse with my laptop? I just changed the battery.
At the receiver u will have a small button and at mouse back side u will have small connector button. After attaching receiver to the into the laptop port just click both receiver and connector button same time. This shud make it work.
23helpful
2answers
How do you set the time on a casio g shock watch????????
I had the same problem following recent daylight savings time (DST) change. The watch has three DST mode settings (ON, OFF, and AUTO). You get to the setting mode by pressing and holding the "adjust' button until the city time zone indicator starts to flash. Then press the "mode" button. This should give you the DST setting. Now press the "receive" button to cycle through the ON, OFF, and AUTO modes for DST. I set it for AUTO. I then existed the setting mode by pressing "adjust" again.
Now you can initiate a manual update of the time by pressing and holding the receive button. Put your watch by a window and make sure the signal strength indication is showing level 4 (full picture of satellite dish on my version). Give it a few minutes to down load new time.
After doing this the watch corrected itself and now shows correct time. Other wise I assume you could set the DST function to ON or OFF as well depending on whether you need to add or subtract the hour from the time.
3helpful
2answers
Microsoft Presenter 3000 does not work
My 3000 has a green light but it only flashes to indicate the sync period during which time you should press the button on the back of the presenter. The presenter works well and to date I have had no problems.
Top Performance Designed Products Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Performance Designed Products Video Game Console and Game Expert? Answer questions, earn points and help others
