I am trying to find out how to remove the round air vent (inside, near the top of the door) so that I can clean some accumulated gunk. I can't see if this is a pressure fit or if it requires a twist. I really don't want to break it.
This is a gray, round plastic vent, with horizontal vent lines. I believe the steam escapes through here and out the front of the door.
Thanks!
SOURCE: vent cover removal from Kenmore 17252 dishwasher door, for cleaning
kayzy If you remove the bottom kick panel you'll find the pouch with technical data on the inside part of it. You will find a complete instruction how to remove the vent. Gendos...post back
SOURCE: water leaks out front
I had exactly the same problem with my Kenmore Ultrawash. I thought the leaking might be coming from the seals around the door, but found that it was leaking from the top as described. I removed the air vent cover on the inside of the door and found that it and the vent area had a great deal of what appeared to be dissolved paper. At first I thought perhaps this was somehow remenents of some kind of air filter, but after reading the post here, came to conclude this was foreign matter. I believe what happended is we at some time washed jars or something with lables on it and this stuff accummulated inside the air vent area. I think in a normal case, when the washer is running, water is mostly stopped from going into the air vent area by the hatched cover, but inevitably some water would get thru. This would be ok normally, because the water would just hit the vent area and probably just fall back into the washer. With all the debris stuck in the vent area and on the cover, I suspect the water was not able to exit the vent area or was hitting the debris and causing the water to jet out the opening to the front - hence the water coming out the vent and pouring down the front. Once I cleaned out the vent area and the cover from the debris, I replaced the cover and ran the washer with no water leaking anymore.
I'm so glad you posted your finding - it gave something to look into, and turned out to be the same source of the problem. You saved me a service call.
SOURCE: My 6 year old Kenmore Elite DW has started leaking
Use a wet/dry shop vac to clean out the strainer and drain from the inside of your machine. A musty smell is a sure sign that food particles have clogged your drain BUT can also mean that your wash/spray heads have become clogged as well. Use a pipe cleaner on the spray heads and run water over the jets to make particles flow to the big hole in the center of your wash heads, then reassemble. Don't forget to put those little plastic looking rings back exactly the way you found them or your wash heads wont turn properly. They are usually made of teflon to lubricate the spray heads.
SOURCE: The pump is running, but the water is not flowing
Number 6 in the picture HERE is the chopper which is probably plugged with food and/or debris. The wing nut you desrcibe turns CLOCKWISE to release the spray arm.
