20 Most Recent KitchenAid Architect Series KEMC308KSS Electric Double Oven Questions & Answers
yes you wilkl need to remov ethe micro from the oven mountingin order to access the light bulb (dumb-design) but no way around it
KitchenAid... | Answered on Jul 09, 2018
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
send me am e mail at b4829@yahoo.com with the model number
Junk it and buy new, do not run this anymore may catch fire.
KitchenAid... | Answered on Jul 08, 2018
On this double oven, each door has it's own latch mechanism that consists of a motor, a position switch, and the door switch used to activate the cavity lights. Because the error indicated a latch failure (and the bottom door was locked), Start by cycling the power to the unit. Each time the power is removed and then applied to these ovens, both latches will lock then unlock the doors to ensure they are in the home open position. By doing so, you might be able to get the bottom oven door opened allowing me access to the latch assembly. With the latch removed, I try to begin a clean cycle so you could watch the motor operate and you will probably find that it will start to turn, but never would rotate enough to lock the door. Since the position switch was not actuated at the end of the motor operation, the F5 E1 error was again displayed. Replace the motor assembly
E
You will need a new igniter module. The igniter module is told to spark by the control panel. There is also a flame detection for electronic start and that could be bad too.
KitchenAid... | Answered on Jan 26, 2018
This is not exactly a solution, but it does explain what F2:E1 means. According to this page, it is a control panel malfunction. It may be caused by a shorted wire, but it may just be the control panel malfunctioning on its own.
KitchenAid... | Answered on Aug 23, 2017
EOC board issue change board
KitchenAid... | Answered on Feb 02, 2017
the door needs to be removed first
KitchenAid... | Answered on Jun 27, 2015
http://www.kitchenaid.com/shop/-[KEMC308KSS]-404327/KEMC308KSS/
http://www.manualslib.com/products/Kitchenaid-Kemc308kss04-262768.html
KitchenAid... | Answered on Feb 25, 2015
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
KitchenAid... | Answered on Jan 24, 2015
gget a new door
KitchenAid... | Answered on Sep 26, 2014
KitchenAid Architect Series KEMC308KSS Electric Double Oven Logo
130 questions posted
Top KitchenAid Ovens Experts
Marvin
Marvin
jdthefixer
Craig Butler
Craig Butler
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Ovens
  • KitchenAid Ovens
Most Popular Question
kitchen aid superba double oven
  • Ovens
