I need the name of the black plastic piece that connects the power nozzle to the stick bottom? It hides the wires of the power nozzle. Where can i get a replacement? Thank you,
SOURCE: Can't clean out a part; need help
The nozzle will seal very tight along the sides, pry up with somethin like a flat blade screwdriver to pry it loose. When you re-install it, make sure the 2 tabes at the top edge of the window snap into the slots first before putting it all of the way down. If you don't then the bucket will sit up slightly and won't suck up the water.
SOURCE: I have a yellowMiele Vacuum,model=Electronic
Generic problem for all Vacuums
posted by maura497 on Apr 18, 2008
Report abuse
I have a yellowMiele Vacuum,model=Electronic Air Clean Plus S3121. On the main body the part that the pipe/nozzle clicks into has a piece that has snapped off. I can see this by lifting the lid and the black plastic piece that is screwed to the inside of the lid has a piece chipped of it which means that when the nozzle is clicked into place it is completely loose. There is a black piece that clicks into the inside of the hoover into this broken part which is still ok so at the moment by lining up the nozzle with this loose piece I can click it into place. How can I get this piece that I need?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can order the order or the schematics from the factory website listed below and I will provide you with another contact as well for the Miele S3121 in order for you to order or replace the part that is broken or you can refer to your local vacuum cleaner dealer in the yellow pages.
http://miele.com 1-800-999-1360 Customer Care
Toll-Free Contact Information
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
www.AVACcorp.com 1-800-328-9430 they can also mail or fax you the info needed to repair or replace the part and they will ship out the product as well
SOURCE: I n eed small plastic white piece that has wire
Could you be looking for a notebook coil spring holder? As an alternative?
