SOURCE: rainbow e2 series
Does the separator turn easily by hand? If it does, may be there is a problem with the carbon brushes. If this model is one that has the computor board mounted on top of the motor, there may be a problem with it.
SOURCE: Rainbow e series smells burnt when power nozzle in use
Replace the belt in the power nozzle, it has to be changed yearly.
SOURCE: Rainbow E series Canister shampooer
i have never used my rainbow shampooer and have had it 2 or 3 years it is not working it will **** up water but will not spray water or shampoo what do i do?
SOURCE: I need to reassemble my rainbow e series electrified hose handle
Yes, it is a ground wire. When you put it back together, make sure that the two halves of the hose handle are holding the wire up against the metal. I just had one apart the other day for the first time and if I recall correctly, the wire goes near the center for reassembly. Hope this helps!
SOURCE: I don't know how to take apart me Rainbow e2 series vac.
I recently took mine apart because the motor stopped working. Realized the brushes were pretty well worn down and one side was completely gone. I was looking on the internet for detailed instructions on how to take it apart. I ended up just ripping it apart with no problems but made a tutorial to help you guys out. Here's a link to it
http://www.vacuumcleanerforum.com/f20/21715-how-take-your-rainbow-vaccum-apart.html
This is for the e-series vaccum, not the e2 but they pretty much have the same design and same motor (e2 has a 2 stage motor).
Let me know if you have any questions
