Currently trying to install Vista X64 drivers for an AR-M277. I found what i believe is the correct driver online. I go through the install process successfully, but when i attatch the printer (via USB) and windows hardware manager takes over, it cannot find a driver for the printer. It correctly names the printer, it searches on windows update for the driver, it asks me to insert disk or specify file, which i have tried both, and regardless it will not find a driver that it finds acceptable to run the printer. Anyone with any experience with this printer and 64bit OS?
SOURCE: SHARP AR-M277
this should resolve it.
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
SOURCE: SHARP AR 5316 DRIVER FOR WINDOWS VISTA X64
try installing using the ar-m205 drivers that come with vista. just go to add printer and scroll down to sharp ar-m205 .......
SOURCE: Reset Error Code F6-10 for Sharp AR-M277
This code is communication problem between the machine and fax board... The battery on the fax board will need to be replaced.
Usually turning off your machine will make this go away, for awhile.
Sometimes preventing your machine from going into Sleep Mode also helps.
The Fax Battery is much like the CMOS battery in a computer.
A large round thin battery, (much like a watch battery)
To replace this, the fax board has to be removed, The battery is
Soldered to the Board, you have to unsolder the battery, then solder
the new battery to the fax board, then reinstall fax board, then set
jumpers on fax board. Turn machine on, do some simulation settings, turn machine
off, remove jumper from fax board. Then restart, hopefully you will not
have to reset the county code.
Unless your experienced with this, do yourself a favor and call a tech..
SOURCE: i am trying to install my ar-m277 on windows vista
you may need updated drivers for that. check the support for that printer.
