Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: I have a Nikon D40X.
From main menu, pick menu with wrench icon, make sure USB is set to "M" mass storage mode. In same menu there is an option for "Folders" to pick which folder to take images from, make sure this is the same as the folder where your images are. Remember that in mass storage mode you can browse the images on the camera as if they were a drive, in windows explorer. You can cut-paste images from camera drive to any folder on your computer.
SOURCE: How to transfer photos from Canon S2IS to laptop
Please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
SOURCE: Unable to transfer photos from memeory card with usb cord
uninstall fuji software from laptop. plug in data cable, pc will ask u for drivers then load it. if not then pause antivirus for while then use data cable
SOURCE: problem transferring photos to computer
Bypass the clumsy software and USB port altogether: see if you can upload to your computer using a CF card reader.
If it works you'll get quicker uploads as well, and if it doesn't work then you have a faulty CF card and will need to try reformatting it (in the camera, not using the pc!) or will have to replace it.
Another possible solution is to reinstall the KM software to your computer as the KM software is quite buggy and seems to corrupt quite easily.
SOURCE: Unable to transfer photos from kodak c330 camera to computer
Start using a card reader to download your pics.
