If I open the door and shut it and hit start it will work for another few minuets
Hello.
what you need to do to solve the problem of the washer is to troubleshoot below are step by step solution on how to solve the problem.
If your washing machine is out of whack, check for these easy fixes
before you spend money and time on a repairman.
1 Make sure the cord is plugged in and that the breaker hasn't tripped.
2 Reset the overload switch - according to the manufacturer's directions - if the machine won't turn on but the breaker hasn't tripped. (Make sure you take some of the clothes out before you run it again or you'll have the same problem.)
3 Check the hot water faucet if the water isn't warm. Also clean the filter screens and make sure that your hot-water heater isn't out of hot water.
4 Make sure the faucets are on, the filters are clean and that the hoses aren't kinked if the washer is filling too slowly.
5 Clear any obstructions in the hose if the clothes are too wet at the end of a cycle. Also, be sure the washer is spinning; if it isn't, remove some of the clothes and redistribute the load. Reset the overload switch. Tighten the drive belt if this doesn't fix the problem.
6 Check the hoses for damage if you are seeing water leaks on the floor.
7 Put a nylon stocking on your hand and feel around the inside of the washer if you are finding snagged or torn clothing. Sand rough spots with fine sandpaper.
Thanks.
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
