I replaced the ice door solenoid, and in doing so I left off the ice and water circuit board for several days and now the fridge wont get cold enough. I followed the controls adjustments as called out in the service manual, one number down per every 12 hrs. There is no defrost problem and the fridge, I think sounds to be operating ok. Help please, thank you
The ref is iced up because of the ice door being left open, you will have to manually defrost the ref by leaving it open for 7-8 hours,put you food somewhere else. 38 years exp burke
I have a GE Side by Side refrigerator, model #GSS25JEMDBB that recently started dripping out the...
(More)
I have a GE Side by Side refrigerator, model #GSS25JEMDBB that recently started dripping out the water dispenser tube. Not heavily, but enough to eventually make it's way to puddle in the floor. The unit is probably around 8 to 10 years old. I have turned water supply off for now.
we have had this refrigerator for over 10 years and it has lost temperature and started to defrost...
(More)
we have had this refrigerator for over 10 years and it has lost temperature and started to defrost about 7 times in about a year. each time I have emptied it and left it unplugged for 1-2 says and then plugged it in again but this time it did it again in about a week. would you suggest getting a new one or would this be worth getting a new one?
Hi, Need to know what a control means for GE model DSS25PFMD WW. We know that the Defrost...
(More)
Hi, Need to know what a control means for GE model DSS25PFMD WW. We know that the Defrost heater&bracket assembly needs to be replace. Does the control need to be replace too?
defrost controls check good. main board reads 24vac to 32vac between j9 and j11 when jumping pins...
(More)
defrost controls check good. main board reads 24vac to 32vac between j9 and j11 when jumping pins system works changed main board system had same problem. what can cause this.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
