It could be as simple as needing to clean the lens that the laser goes through that reads the disk. there are cleaners available for purchase at any retail outlet. If this doesn't fix it then it could be that you have an internal circuitry malfunction. you stated that you hear a fan inside turn on this is a good sign,however there is still a good amount of heat inside to the internal circuit board. over time they tend to fail even though the fan is working. your 2 choices at this point is either have it repaired(the cost of which could be more than the deck is worth and also providing they have the parts for it) or you can just purchase a new one that is better in technology and will have a better usefulness. hope this helps you...please rate the solution.......thanks
Hi
Thank you
TRY TO DO A OPTICAL HEAD CLEANING ON THE UNIT.. IT IS POSSIBLE THAT THE OPTICAL READER IS DIRTY. AND MUST NEEDED TO BE CLEAN.. USE A CD CLEANER TO DO THIS...
KEEP US UPDATED.,
YOU MUST FIRST TRY TO DO HEAD CLEANING. BEFORE WE GO ON ANOTHER PROCEDURE.. YES IT WILL READ A NON BLANK DISC BUT LATER ON IT WILL NOT AGAIN READ ANOTHER DISC
Seems a little indecisive...I didn't approach fix it to get a new one...maybe there is some other solution ?
WHAT DO U MEAN FOR THIS MEN...?
Headb cleaner does not seem necessary as it id reading non blank discs
I will try the head cleaner & report back
