Maytag EPIC MFW9700S Front Load Washer Logo
Anonymous Posted on Sep 21, 2011
Gives code f02 and sud - Maytag EPIC MFW9700S Front Load Washer
Anonymous
Level 3:
  • Master 2,341 Answers
  • Posted on Sep 21, 2011
Anonymous
Master
Level 3:
Answers
2341
Questions
Helped
636874
Points
7414
The F2 error codes means LONG DRAIN TIME and the suds code the washer detected water in tub after normal alloted drain time...so basically the F2&SUDS means the same thing. A lot of times when it does not drain fast enough,its caused by a blocked filter on the pump being biult up with debris. This tip i wrote will show ya how to clean the pump filter.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Why is it displaying SUD and F02?
remove the top of the unit and inside is the trouble code paper work that will guide you to anything that is wrong.
Received a SUD error
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Whirlpool Fault Codes
1helpful
What does it mean when sud appears on the display screen and the washers seems like its not doing anything?
Hi, W/D here.
What you are seeing is the suds (SUD) error code, and is sometimes followed by a long drain fault code (F02).
This does not necessarily indicate that you need to change anything at this time. When the machine senses too much suds, the error code is displayed, when too much suds are actually present, a longer drain time results.
Duets are HE (high efficiency) machines, and require a detergent that produces little suds. If you are using HE detergent, cut back on it until you can run a cycle without getting the SUD/F02 alarms. If you are not using HE detergent (we don't either), you really have to be careful with the amount of detergent used.
Press PAUSE/CANCEL twice to clear the display. Run a cycle without any detergent to flush the machine.
You need to check that the drain hose isn't plugged or have a kink in it.
Make sure that the pump is running. You may need to check the electrical connections at the pump.
Check the filter on the drain pump for debris or foreign objects, which might cause the drain cycle to be extended, if you are also getting the F02 code.
If limiting the detergent, and nothing was found in checking the other items listed, then the pump may need to be replaced.
Best regards, --W/D--
Hello...my Whilpool Duet washer keeps giving a SUD and F02 error. Now...this just happened a couple months ago and we replaced the Drain Pump Assembly...is it possible that we are once again going to have...
Hello, W/D here.
What you are seeing is the suds (SUD) error code, followed by a long drain fault code (F02).
It is advisable to check that the drain hose isn't plugged or have a kink in it.
You might check the filter on the drain pump for debris or foreign objects, which might cause the drain cycle to be extended.
Please help us by rating our solutions. Thanks.
2helpful
Whirlpool AWM9000 front loader Gives SUD on display then F02 and beeps.
it is a Long Drain error
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Thank You
1helpful
2answers
Our Whirpool duet washer will not spin, gives us the SUDS and F02 message and now the door is locked.....suggestionss?
k now the washer beleives that it is full of water.
pour about 3/4 cup of veg oil in the dispenser. and start the unit.. this will get rid of the suds error.
F02 means long fill.. and the water level has not satisfied the computer for 40 secs. check water connections. making sure they are fully open.
to open the door if it does not unlock, in the dispenser there should be an ODD colored line, five that a tug and the door will pop open
It stops in the middle of a cycle and gives an F02 problem.
F02 Long Drain
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
Persistent F02 / SUD error. Tried all the tricks!
how about the line from pump to bottom of tank?not excess suds?might be bad control bd..f code is generated when control bd senses incorrect current draw by drain motor ..could be glitch in readings or a misread
Error codes
I own a HE3 kenmore elite for 4 years now and the troubleshooting codes are: SUD When excessive suds are detected, a suds routine automatically starts. This causes the cycle to go longer to remove the excess suds. Reduce detergent amounts or use HE detergent. The F02 error I had with mine and it is a drain problem. Book says check the hose for kinks, clogged or is it more than 96 inches above the floor. On mine it was the fan pump on the forward motor that drains the washer. It was worn and not pushing out the water fast enough. You will hear a high pitched whine at the front bottom of the washer if this is bad. To reset the washer from the F02 error, select pause/cancel twice to cancel the cycle. Unplug washer or dissconnect power. good luck
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
