Sony VGPUVC100 VAIO Webcam Logo
Posted on Sep 04, 2011
After starting my laptop one desktop icon is autometically selected. after pressing shift or ctrl key 2-3 times a dialog box open, in which a message is written- turn on sticky keys???? yes/no. after that normal processing is continued. sometimes when i am working it again activated and scroll upward.
5 Related Answers
Open SKy
Carlos L. Burgos
  • 620 Answers
  • Posted on Dec 06, 2007
SOURCE: display property settings
Hello Phil 65
Happy Holidays
well, the best bet for you, is uninstall the Driver for your video card, from device manager , and ADD/Remove programs, your other features for the particular video card. ONLY.
then go ahead and restart your PC, reinstall drivers according, and have your CD for video drivers and settings program.
that should restore your video , ....or use the Windows Restore point feature to a date all work fine.
good luck
Anonymous
  • 58 Answers
  • Posted on May 11, 2008
SOURCE: no task bar or icons only desktop picture
start up in safe mode by pushing the f8 key on startup this will give you networking capabilities then follow these instructions
Hijackthis is a first line tool to examine certain areas of the computer. It does not show everything and lots of malware is hidden from it
To download Hijackthis
go to http://www.merijn.org/programs.php and download 'Hijack This!' self installer. Save it to the desktop or other suitable place. DO NOT just press run from the website Double click on the file and it will install to C:\program files\hijackthis and create an entry in the start menu.
Click on the entry in start menu to run HijackThis
Click the "Scan" button, when the scan is finished the scan button will become "Save Log" click that and save the log.
Go to where you saved the log and click on "Edit > Select All" then click on "Edit > Copy" then Paste the log back here in a reply.
It will possibly show issues deserving our attention, but most of what it lists will be harmless or even required,
so do NOT fix anything yet.
Someone here will be happy to help you analyze the results.
feel free to e-mail me
Thank you Ian C. [email protected]
Anonymous
  • 41 Answers
  • Posted on Mar 10, 2009
SOURCE: My Desktop Computer won't start up.
Mine has crashed. So has yours. It has crashed. You must try to boot it with a boot disc made for the operating system. As its 8 years old the manufacturer wont sell you a boot disk but you can buy a boot disk for the correct version ofwindows
tbirdfan1
Michael Thomas
  • 3056 Answers
  • Posted on May 27, 2010
SOURCE: Sticky FN Key problem
Hello there:
Laptop keyboards are notorious for sticking after time due to small particles of dirt or oils from our skin and if you smoke believe it or not smoke from a cigarette is very bad on keyboards and computers in general.
What you can do to try to solve this problem is to get a can of canned air then turn off the laptop and dissconnect the power cord then
get a very small flat tip screw driver and CAREFULLY pry off the faulty key pad then take a q tip and some rubbing alcohol and wipe the area that it connects to .
Now take the canned air and spray down the entire keyboard and let sit for 10 minutes then replace the key pad and then replace the power cord and turn on the laptop and see if this now will work ok
Please keep me posted on how this is going
Best regards Michael
Testimonial: "Man, I'm gonna test this after work... can you mail me? Sony's esupport told me somethings... [email protected] Thanks a lot! All the best."
Anonymous
  • Posted on Dec 15, 2012
SOURCE: sony vaio keyboard specific keys not working; backspace, left shift, 1,3,5,7,9, P. Software not hardware related.
press both shift and hold it for awhile , see if it starts working.
tip
Windows xp keyboard tips
and also
and
Windows system key combinations
  • F1: Help
  • CTRL+ESC: Open Start menu
  • ALT+TAB: Switch between open programs
  • ALT+F4: Quit program
  • SHIFT+DELETE: Delete item permanently
  • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
Windows program key combinations
  • CTRL+C: Copy
  • CTRL+X: Cut
  • CTRL+V: Paste
  • CTRL+Z: Undo
  • CTRL+B: Bold
  • CTRL+U: Underline
  • CTRL+I: Italic
Mouse click/keyboard modifier combinations for shell objects
  • SHIFT+right click: Displays a shortcut menu containing alternative commands
  • SHIFT+double click: Runs the alternate default command (the second item on the menu)
  • ALT+double click: Displays properties
  • SHIFT+DELETE: Deletes an item immediately without placing it in the Recycle Bin
General keyboard-only commands
  • F1: Starts Windows Help
  • F10: Activates menu bar options
  • SHIFT+F10 Opens a shortcut menu for the selected item (this is the same as right-clicking an object
  • CTRL+ESC: Opens the Start menu (use the ARROW keys to select an item)
  • CTRL+ESC or ESC: Selects the Start button (press TAB to select the taskbar, or press SHIFT+F10 for a context menu)
  • CTRL+SHIFT+ESC: Opens Windows Task Manager
  • ALT+DOWN ARROW: Opens a drop-down list box
  • ALT+TAB: Switch to another running program (hold down the ALT key and then press the TAB key to view the task-switching window)
  • SHIFT: Press and hold down the SHIFT key while you insert a CD-ROM to bypass the automatic-run feature
  • ALT+SPACE: Displays the main window's System menu (from the System menu, you can restore, move, resize, minimize, maximize, or close the window)
  • ALT+- (ALT+hyphen): Displays the Multiple Document Interface (MDI) child window's System menu (from the MDI child window's System menu, you can restore, move, resize, minimize, maximize, or close the child window)
  • CTRL+TAB: Switch to the next child window of a Multiple Document Interface (MDI) program
  • ALT+underlined letter in menu: Opens the menu
  • ALT+F4: Closes the current window
  • CTRL+F4: Closes the current Multiple Document Interface (MDI) window
  • ALT+F6: Switch between multiple windows in the same program (for example, when the Notepad Find dialog box is displayed, ALT+F6 switches between the Find dialog box and the main Notepad window)
Shell objects and general folder/Windows Explorer shortcuts
For a selected object:
  • F2: Rename object
  • F3: Find all files
  • CTRL+X: Cut
  • CTRL+C: Copy
  • CTRL+V: Paste
  • SHIFT+DELETE: Delete selection immediately, without moving the item to the Recycle Bin
  • ALT+ENTER: Open the properties for the selected object
To copy a file
Press and hold down the CTRL key while you drag the file to another folder.
To create a shortcut
Press and hold down CTRL+SHIFT while you drag a file to the desktop or a folder.
General folder/shortcut control
  • F4: Selects the Go To A Different Folder box and moves down the entries in the box (if the toolbar is active in Windows Explorer)
  • F5: Refreshes the current window.
  • F6: Moves among panes in Windows Explorer
  • CTRL+G: Opens the Go To Folder tool (in Windows 95 Windows Explorer only)
  • CTRL+Z: Undo the last command
  • CTRL+A: Select all the items in the current window
  • BACKSPACE: Switch to the parent folder
  • SHIFT+click+Close button: For folders, close the current folder plus all parent folders
Windows Explorer tree control
  • Numeric Keypad *: Expands everything under the current selection
  • Numeric Keypad +: Expands the current selection
  • Numeric Keypad -: Collapses the current selection.
  • RIGHT ARROW: Expands the current selection if it is not expanded, otherwise goes to the first child
  • LEFT ARROW: Collapses the current selection if it is expanded, otherwise goes to the parent
Properties control
  • CTRL+TAB/CTRL+SHIFT+TAB: Move through the property tabs
Accessibility shortcuts
  • Press SHIFT five times: Toggles StickyKeys on and off
  • Press down and hold the right SHIFT key for eight seconds: Toggles FilterKeys on and off
  • Press down and hold the NUM LOCK key for five seconds: Toggles ToggleKeys on and off
  • Left ALT+left SHIFT+NUM LOCK: Toggles MouseKeys on and off
  • Left ALT+left SHIFT+PRINT SCREEN: Toggles high contrast on and off
Microsoft Natural Keyboard keys
  • Windows Logo: Start menu
  • Windows Logo+R: Run dialog box
  • Windows Logo+M: Minimize all
  • SHIFT+Windows Logo+M: Undo minimize all
  • Windows Logo+F1: Help
  • Windows Logo+E: Windows Explorer
  • Windows Logo+F: Find files or folders
  • Windows Logo+D: Minimizes all open windows and displays the desktop
  • CTRL+Windows Logo+F: Find computer
  • CTRL+Windows Logo+TAB: Moves focus from Start, to the Quick Launch toolbar, to the system tray (use RIGHT ARROW or LEFT ARROW to move focus to items on the Quick Launch toolbar and the system tray)
  • Windows Logo+TAB: Cycle through taskbar buttons
  • Windows Logo+Break: System Properties dialog box
  • Application key: Displays a shortcut menu for the selected item
Microsoft Natural Keyboard with IntelliType software installed
  • Windows Logo+L: Log off Windows
  • Windows Logo+P: Starts Print Manager
  • Windows Logo+C: Opens Control Panel
  • Windows Logo+V: Starts Clipboard
  • Windows Logo+K: Opens Keyboard Properties dialog box
  • Windows Logo+I: Opens Mouse Properties dialog box
  • Windows Logo+A: Starts Accessibility Options (if installed)
  • Windows Logo+SPACEBAR: Displays the list of Microsoft IntelliType shortcut keys
  • Windows Logo+S: Toggles CAPS LOCK on and off
Dialog box keyboard commands
  • TAB: Move to the next control in the dialog box
  • SHIFT+TAB: Move to the previous control in the dialog box
  • SPACEBAR: If the current control is a button, this clicks the button. If the current control is a check box, this toggles the check box. If the current control is an option, this selects the option.
  • ENTER: Equivalent to clicking the selected button (the button with the outline)
  • ESC: Equivalent to clicking the Cancel button
  • ALT+underlined letter in dialog box item: Move to the corresponding item
reference: http://support.microsoft.com/kb/126449
My friends laptop starts up and only loads the wallpaper on the desktop homepage, no icons or start menu appear.
Don't worry when your friends laptop starts and if nothing is displayed then Press Ctrl Alt Del keys on your key board.Just see that you have pressed all the keys at same time or first press Ctrl then keep it pressed and with another finger press Alt and also keep it pressed and at last press Del key.
You will find task manager opened on the screen .There you will find File option ,click on it and select New task from the drop down.
Another dialog box will open type there explorer.exe and click OK.
Your problem will be fixed then.
Thanks,
Have a great day
2helpful
Guide
General keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+C (Copy)
  • CTRL+X (Cut)
  • CTRL+V (Paste)
  • CTRL+Z (Undo)
  • DELETE (Delete)
  • SHIFT+DELETE (Delete the selected item permanently without placing the item in the Recycle Bin)
  • CTRL while dragging an item (Copy the selected item)
  • CTRL+SHIFT while dragging an item (Create a shortcut to the selected item)
  • F2 key (Rename the selected item)
  • CTRL+RIGHT ARROW (Move the insertion point to the beginning of the next word)
  • CTRL+LEFT ARROW (Move the insertion point to the beginning of the previous word)
  • CTRL+DOWN ARROW (Move the insertion point to the beginning of the next paragraph)
  • CTRL+UP ARROW (Move the insertion point to the beginning of the previous paragraph)
  • CTRL+SHIFT with any of the arrow keys (Highlight a block of text)
  • SHIFT with any of the arrow keys (Select more than one item in a window or on the desktop, or select text in a document)
  • CTRL+A (Select all)
  • F3 key (Search for a file or a folder)
  • ALT+ENTER (View the properties for the selected item)
  • ALT+F4 (Close the active item, or quit the active program)
  • ALT+ENTER (Display the properties of the selected object)
  • ALT+SPACEBAR (Open the shortcut menu for the active window)
  • CTRL+F4 (Close the active document in programs that enable you to have multiple documents open simultaneously)
  • ALT+TAB (Switch between the open items)
  • ALT+ESC (Cycle through items in the order that they had been opened)
  • F6 key (Cycle through the screen elements in a window or on the desktop)
  • F4 key (Display the Address bar list in My Computer or Windows Explorer)
  • SHIFT+F10 (Display the shortcut menu for the selected item)
  • ALT+SPACEBAR (Display the System menu for the active window)
  • CTRL+ESC (Display the Start menu)
  • ALT+Underlined letter in a menu name (Display the corresponding menu)
  • Underlined letter in a command name on an open menu (Perform the corresponding command)
  • F10 key (Activate the menu bar in the active program)
  • RIGHT ARROW (Open the next menu to the right, or open a submenu)
  • LEFT ARROW (Open the next menu to the left, or close a submenu)
  • F5 key (Update the active window)
  • BACKSPACE (View the folder one level up in My Computer or Windows Explorer)
  • ESC (Cancel the current task)
  • SHIFT when you insert a CD-ROM into the CD-ROM drive (Prevent the CD-ROM from automatically playing)
  • CTRL+SHIFT+ESC (Open Task Manager)
Dialog box keyboard shortcuts loadTOCNode(2, 'moreinformation'); If you press SHIFT+F8 in extended selection list boxes, you enable extended selection mode. In this mode, you can use an arrow key to move a cursor without changing the selection. You can press CTRL+SPACEBAR or SHIFT+SPACEBAR to adjust the selection. To cancel extended selection mode, press SHIFT+F8 again. Extended selection mode cancels itself when you move the focus to another control.
  • CTRL+TAB (Move forward through the tabs)
  • CTRL+SHIFT+TAB (Move backward through the tabs)
  • TAB (Move forward through the options)
  • SHIFT+TAB (Move backward through the options)
  • ALT+Underlined letter (Perform the corresponding command or select the corresponding option)
  • ENTER (Perform the command for the active option or button)
  • SPACEBAR (Select or clear the check box if the active option is a check box)
  • Arrow keys (Select a button if the active option is a group of option buttons)
  • F1 key (Display Help)
  • F4 key (Display the items in the active list)
  • BACKSPACE (Open a folder one level up if a folder is selected in the Save As or Open dialog box)
Microsoft natural keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • Windows Logo (Display or hide the Start menu)
  • Windows Logo+BREAK (Display the System Properties dialog box)
  • Windows Logo+D (Display the desktop)
  • Windows Logo+M (Minimize all of the windows)
  • Windows Logo+SHIFT+M (Restore the minimized windows)
  • Windows Logo+E (Open My Computer)
  • Windows Logo+F (Search for a file or a folder)
  • CTRL+Windows Logo+F (Search for computers)
  • Windows Logo+F1 (Display Windows Help)
  • Windows Logo+ L (Lock the keyboard)
  • Windows Logo+R (Open the Run dialog box)
  • Windows Logo+U (Open Utility Manager)
Accessibility keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • Right SHIFT for eight seconds (Switch FilterKeys either on or off)
  • Left ALT+left SHIFT+PRINT SCREEN (Switch High Contrast either on or off)
  • Left ALT+left SHIFT+NUM LOCK (Switch the MouseKeys either on or off)
  • SHIFT five times (Switch the StickyKeys either on or off)
  • NUM LOCK for five seconds (Switch the ToggleKeys either on or off)
  • Windows Logo +U (Open Utility Manager)
Windows Explorer keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • END (Display the bottom of the active window)
  • HOME (Display the top of the active window)
  • NUM LOCK+Asterisk sign (*) (Display all of the subfolders that are under the selected folder)
  • NUM LOCK+Plus sign (+) (Display the contents of the selected folder)
  • NUM LOCK+Minus sign (-) (Collapse the selected folder)
  • LEFT ARROW (Collapse the current selection if it is expanded, or select the parent folder)
  • RIGHT ARROW (Display the current selection if it is collapsed, or select the first subfolder)
Shortcut keys for Character Map loadTOCNode(2, 'moreinformation'); After you double-click a character on the grid of characters, you can move through the grid by using the keyboard shortcuts:
  • RIGHT ARROW (Move to the right or to the beginning of the next line)
  • LEFT ARROW (Move to the left or to the end of the previous line)
  • UP ARROW (Move up one row)
  • DOWN ARROW (Move down one row)
  • PAGE UP (Move up one screen at a time)
  • PAGE DOWN (Move down one screen at a time)
  • HOME (Move to the beginning of the line)
  • END (Move to the end of the line)
  • CTRL+HOME (Move to the first character)
  • CTRL+END (Move to the last character)
  • SPACEBAR (Switch between Enlarged and Normal mode when a character is selected)
Microsoft Management Console (MMC) main window keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+O (Open a saved console)
  • CTRL+N (Open a new console)
  • CTRL+S (Save the open console)
  • CTRL+M (Add or remove a console item)
  • CTRL+W (Open a new window)
  • F5 key (Update the content of all console windows)
  • ALT+SPACEBAR (Display the MMC window menu)
  • ALT+F4 (Close the console)
  • ALT+A (Display the Action menu)
  • ALT+V (Display the View menu)
  • ALT+F (Display the File menu)
  • ALT+O (Display the Favorites menu)
MMC console window keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+P (Print the current page or active pane)
  • ALT+Minus sign (-) (Display the window menu for the active console window)
  • SHIFT+F10 (Display the Action shortcut menu for the selected item)
  • F1 key (Open the Help topic, if any, for the selected item)
  • CTRL+F10 (Maximize the active console window)
  • CTRL+F5 (Restore the active console window)
  • ALT+ENTER (Display the Properties dialog box, if any, for the selected item)
  • CTRL+F4 (Close the active console window. When a console has only one console window, this shortcut closes the console)
tip
Amazing shortcuts
Getting used to using your keyboard exclusively and leaving your mouse behind will make you much more efficient at performing any task on any Windows system. I use the following keyboard shortcuts every day:<br /><br />Windows key + R = Run menu<br /><br />This is usually followed by:<br />cmd = Command Prompt<br />iexplore + "web address" = Internet Explorer<br />compmgmt.msc = Computer Management<br />dhcpmgmt.msc = DHCP Management<br />dnsmgmt.msc = DNS Management<br />services.msc = Services<br />eventvwr = Event Viewer<br />dsa.msc = Active Directory Users and Computers<br />dssite.msc = Active Directory Sites and Services<br />Windows key + E = Explorer<br /><br />ALT + Tab = Switch between windows<br /><br />ALT, Space, X = Maximize window<br /><br />CTRL + Shift + Esc = Task Manager<br /><br />Windows key + Break = System properties<br /><br />Windows key + F = Search<br /><br />Windows key + D = Hide/Display all windows<br /><br />CTRL + C = copy<br /><br />CTRL + X = cut<br /><br />CTRL + V = paste<br /><br />Also don't forget about the "Right-click" key next to the right Windows key on your keyboard. Using the arrows and that key can get just about anything done once you've opened up any program.<br /><br /><br />Keyboard Shortcuts<br /><br />[Alt] and [Esc] Switch between running applications<br /><br />[Alt] and letter Select menu item by underlined letter<br /><br />[Ctrl] and [Esc] Open Program Menu<br /><br />[Ctrl] and [F4] Close active document or group windows (does not work with some applications)<br /><br />[Alt] and [F4] Quit active application or close current window<br /><br />[Alt] and [-] Open Control menu for active document<br /><br />Ctrl] Lft., Rt. arrow Move cursor forward or back one word<br /><br />Ctrl] Up, Down arrow Move cursor forward or back one paragraph<br /><br />[F1] Open Help for active application<br /><br />Windows+M Minimize all open windows<br /><br />Shift+Windows+M Undo minimize all open windows<br /><br />Windows+F1 Open Windows Help<br /><br />Windows+Tab Cycle through the Taskbar buttons<br /><br />Windows+Break Open the System Properties dialog box<br /><br /><br /><br />acessability shortcuts<br /><br />Right SHIFT for eight seconds........ Switch FilterKeys on and off.<br /><br />Left ALT +left SHIFT +PRINT SCREEN....... Switch High Contrast on and off.<br /><br />Left ALT +left SHIFT +NUM LOCK....... Switch MouseKeys on and off.<br /><br />SHIFT....... five times Switch StickyKeys on and off.<br /><br />NUM LOCK...... for five seconds Switch ToggleKeys on and off.<br /><br />explorer shortcuts<br /><br />END....... Display the bottom of the active window.<br /><br />HOME....... Display the top of the active window.<br /><br />NUM LOCK+ASTERISK....... on numeric keypad (*) Display all subfolders under the selected folder.<br /><br />NUM LOCK+PLUS SIGN....... on numeric keypad (+) Display the contents of the selected folder.<br /><br />NUM LOCK+MINUS SIGN....... on numeric keypad (-) Collapse the selected folder.<br /><br />LEFT ARROW...... Collapse current selection if it's expanded, or select parent folder.<br /><br />RIGHT ARROW....... Display current selection if it's collapsed, or select first subfolder.<br /><br /><br /><br /><br />Type the following commands in your Run Box (Windows Key + R) or Start Run<br /><br />devmgmt.msc = Device Manager<br />msinfo32 = System Information<br />cleanmgr = Disk Cleanup<br />ntbackup = Backup or Restore Wizard (Windows Backup Utility)<br />mmc = Microsoft Management Console<br />excel = Microsoft Excel (If Installed)<br />msaccess = Microsoft Access (If Installed)<br />powerpnt = Microsoft PowerPoint (If Installed)<br />winword = Microsoft Word (If Installed)<br />frontpg = Microsoft FrontPage (If Installed)<br />notepad = Notepad<br />wordpad = WordPad<br />calc = Calculator<br />msmsgs = Windows Messenger<br />mspaint = Microsoft Paint<br />wmplayer = Windows Media Player<br />rstrui = System Restore<br />netscp6 = Netscape 6.x<br />netscp = Netscape 7.x<br />netscape = Netscape 4.x<br />waol = America Online<br />control = Opens the Control Panel<br />control printers = Opens the Printers Dialog<br /><br /><br />internetbrowser<br /><br />type in u're adress "google", then press [Right CTRL] and [Enter]<br />add www. and .com to word and go to it<br /><br /><br />For Windows XP:<br /><br />Copy. CTRL+C<br />Cut. CTRL+X<br />Paste. CTRL+V<br />Undo. CTRL+Z<br />Delete. DELETE<br />Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE<br />Copy selected item. CTRL while dragging an item<br />Create shortcut to selected item. CTRL+SHIFT while dragging an item<br />Rename selected item. F2<br />Move the insertion point to the beginning of the next word. CTRL+RIGHT ARROW<br />Move the insertion point to the beginning of the previous word. CTRL+LEFT ARROW<br />Move the insertion point to the beginning of the next paragraph. CTRL+DOWN ARROW<br />Move the insertion point to the beginning of the previous paragraph. CTRL+UP ARROW<br />Highlight a block of text. CTRL+SHIFT with any of the arrow keys<br />Select more than one item in a window or on the desktop, or select text within a document. SHIFT with any of the arrow keys<br />Select all. CTRL+A<br />Search for a file or folder. F3<br />View properties for the selected item. ALT+ENTER<br />Close the active item, or quit the active program. ALT+F4<br />Opens the shortcut menu for the active window. ALT+SPACEBAR<br />Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4<br />Switch between open items. ALT+TAB<br />Cycle through items in the order they were opened. ALT+ESC<br />Cycle through screen elements in a window or on the desktop. F6<br />Display the Address bar list in My Computer or Windows Explorer. F4<br />Display the shortcut menu for the selected item. SHIFT+F10<br />Display the System menu for the active window. ALT+SPACEBAR<br />Display the Start menu. CTRL+ESC<br />Display the corresponding menu. ALT+Underlined letter in a menu name<br />Carry out the corresponding command. Underlined letter in a command name on an open menu<br />Activate the menu bar in the active program. F10<br />Open the next menu to the right, or open a submenu. RIGHT ARROW<br />Open the next menu to the left, or close a submenu. LEFT ARROW<br />Refresh the active window. F5<br />View the folder one level up in My Computer or Windows Explorer. BACKSPACE<br />Cancel the current task. ESC<br />SHIFT when you insert a CD into the CD-ROM drive Prevent the CD from automatically playing.<br /><br />Use these keyboard shortcuts for dialog boxes:<br /><br />To Press<br />Move forward through tabs. CTRL+TAB<br />Move backward through tabs. CTRL+SHIFT+TAB<br />Move forward through options. TAB<br />Move backward through options. SHIFT+TAB<br />Carry out the corresponding command or select the corresponding option. ALT+Underlined letter<br />Carry out the command for the active option or button. ENTER<br />Select or clear the check box if the active option is a check box. SPACEBAR<br />Select a button if the active option is a group of option buttons. Arrow keys<br />Display Help. F1<br />Display the items in the active list. F4<br />Open a folder one level up if a folder is selected in the Save As or Open dialog box. BACKSPACE<br /><br />If you have a Microsoft Natural Keyboard, or any other compatible keyboard that includes the Windows logo key and the Application key , you can use these keyboard shortcuts:<br /><br /><br />Display or hide the Start menu. WIN Key<br />Display the System Properties dialog box. WIN Key+BREAK<br />Show the desktop. WIN Key+D<br />Minimize all windows. WIN Key+M<br />Restores minimized windows. WIN Key+Shift+M<br />Open My Computer. WIN Key+E<br />Search for a file or folder. WIN Key+F<br />Search for computers. CTRL+WIN Key+F<br />Display Windows Help. WIN Key+F1<br />Lock your computer if you are connected to a network domain, or switch users if you are not connected to a network domain. WIN Key+ L<br />Open the Run dialog box. WIN Key+R<br />Open Utility Manager. WIN Key+U<br /><br />accessibility keyboard shortcuts:<br /><br />Switch FilterKeys on and off. Right SHIFT for eight seconds<br />Switch High Contrast on and off. Left ALT+left SHIFT+PRINT SCREEN<br />Switch MouseKeys on and off. Left ALT +left SHIFT +NUM LOCK<br />Switch StickyKeys on and off. SHIFT five times<br />Switch ToggleKeys on and off. NUM LOCK for five seconds<br />Open Utility Manager. WIN Key+U<br /><br />shortcuts you can use with Windows Explorer:<br /><br /><br />Display the bottom of the active window. END<br />Display the top of the active window. HOME<br />Display all subfolders under the selected folder. NUM LOCK+ASTERISK on numeric keypad (*)<br />Display the contents of the selected folder. NUM LOCK+PLUS SIGN on numeric keypad (+)<br />Collapse the selected folder. NUM LOCK+MINUS SIGN on numeric keypad (-)<br />Collapse current selection if it's expanded, or select parent folder. LEFT ARROW<br />Display current selection if it's collapsed, or select first subfolder. RIGHT ARROW<br /><br />
on Jan 10, 2011 • Computers & Internet
tip
Keyboard shortcuts for Microsoft Windows XP, Vista, 7 and Microsoft Office
Windows
Windows Key+E
This shortcut allows you to open Windows Explorer with one quick keystroke.
Alt+Tab
This allows you to easily toggle back and forth between all the windows you have open. You can also use this to switch between windows in the same program, making multitasking real easy.
Windows key+Tab
This lets you scroll the items on the taskbar, and in Vista, it starts Flip 3D for a fun graphical spin on the same idea.
Alt+F4
This shortcut is a quick way to close a window in any program without using your mouse to hit the X in the upper-right corner.
Windows Key+M
This allows you to minimize all of your open windows, leaving just the desktop left exposed. To restore the windows, hit Windows key+Shift+M. Another quick way to do this is Windows key+D, which shows your desktop; to restore, just repeat the same keystroke.
Ctrl+Drag
There are many ways to copy a file, but this just might be the easiest. All you have to do is click on the file, hold, and drag it into its desired location. This works the same as another handy shortcut, Ctrl+C.
Windows Key+U+U
This is the shortcut for quickly shutting down Windows by hitting the Windows key (don't hold it down), hitting U to reach the shutdown menu, and then hitting U again to shut down.
Windows Key+Pause
This is a quick way to get to the Systems Properties menu.
Shift+Delete
If you want to delete a file-and you don't want to deal with it later in the Recycle Bin-this is the way to go. Just be absolutely sure that this is a file you won't want back!
To bypass the Autorun when inserting a CD
Hold Shift While Inserting the CD.
Microsoft Office
Ctrl+U, Ctrl+B, Ctrl+I
Used to snap to underline, bold, and italicize without the mouse if you press Ctrl+U (underlining), Ctrl+B (bolding), or Ctrl+I (italicizing).
Shift + Arrow Keys
Holding shift and pressing one of the arrow keys will highlight text in Word (or a group of Excel cells) without the mouse, selecting in the direction the arrow points.
Ctrl+Z, Ctrl+Y
Undo an action by hitting Ctrl+Z; if you change your mind, Ctrl+Y will redo the undo.
Microsoft Office - Excel
F1
Opens a help task pane
F1 + Ctrl
Opens or closes the help window
F2
To edit the text in the active cell
F2 + Shift
To write a comment in the active cell
F2 + Alt
Opens the save as dialog box
F3 + Shift
Opens the insert dialog box
F3 + Ctrl
Opens the define name dialog box
F3 + Shift + Ctrl
Opens the create name dialog box
F4
To redo the last command
F4 + Ctrl
To close the workbook window
F4 + Alt
To close the excel program
F5
Opens the Goto dialog box
F5 + Ctrl
brings back to the first level of workbook
F6
To shift between help taskbar and the excel window
F6 + Shift
To goto the previous square in the open worksheet
F6 + Ctrl
If more than one workbook is open to switch between them
F7
To open spelling correction window
F7 + Ctrl
When workbook window is not maximised it will move the window
F8
To activate / deactivate extended mode
F9
Will calculate all the worksheets in all open workbooks
F9 + Shift
Will calculate the active worksheet
F9 + Ctrl
To Minimise the workbook window
F10
Will select the menu bar
F10 + Ctrl
To open minimised window
F11
Will create a chart using the current range
F11 + Shift
To select a new worksheet
F11 + Alt
To switch between visual basic editor and the worksheet
F11 + Alt + Shift
Opens microsoft script editor
F12
Opens save as dialog box
F12 + Shift
Saves the active workbook
F12 + Ctrl
To open the Open dialog box
F12 + Ctrl + Shift
Opens the print dialog box
on Jan 01, 2011 • Computers & Internet
tip
CTRL+C (Copy) CTRL+X (Cut) CTRL+V (Paste) CTRL+Z (Undo) DELETE (Delete)...
CTRL+V (Paste)
CTRL+Z (Undo)
DELETE (Delete)
CTRL+A (Select all)
Dialog Box Keyboard Shortcuts
Accessibility Keyboard Shortcuts
Windows Explorer Keyboard Shortcuts
Microsoft Management Console (MMC) Main Window Keyboard Shortcuts
Remote Desktop Connection Navigation
CTRL+ALT+END (Open the Microsoft Windows NT Security dialog box)
ALT+PAGE UP (Switch between programs from left to right)
ALT+PAGE DOWN (Switch between programs from right to left)
ALT+INSERT (Cycle through the programs in most recently used order)
ALT+HOME (Display the Start menu)
MMC Console Window Keyboard Shortcuts
CTRL+ALT+BREAK (Switch the client computer between a window and a full screen)
ALT+DELETE (Display the Windows menu)
CTRL+ALT+Minus sign (-) (Place a snapshot of the active window in the client on the Terminal server clipboard and provide the same functionality as pressing PRINT SCREEN on a local computer.)
CTRL+ALT+Plus sign (+) (Place a snapshot of the entire client window area on the Terminal server clipboard and provide the same functionality as pressing ALT+PRINT SCREEN on a local computer.)
Microsoft Internet Explorer Navigation
CTRL+I (Open the Favorites bar)
CTRL+L (Open the Open dialog box)
CTRL+N (Start another instance of the browser with the same Web address)
CTRL+O (Open the Open dialog box, the same as CTRL+L)
CTRL+P (Open the Print dialog box)
CTRL+R (Update the current Web page)
CTRL+B (Open the Organize Favorites dialog box)
CTRL+E (Open the Search bar)
CTRL+H (Open the History bar)
on Jul 25, 2010 • Computers & Internet
tip
Windows General Keyboard shortcuts
CTRL+V (Paste)
CTRL+Z (Undo)
DELETE (Delete)
CTRL+A (Select all)
tip
CTRL+C (Copy)
CTRL+X (Cut)
CTRL+V (Paste)
CTRL+Z (Undo)
DELETE (Delete)
CTRL+A (Select all)
Microsoft Natural Keyboard Shortcuts
Shortcut Keys for Character Map
CTRL+F (Start the Find utility)
CTRL+W (Close the current window)
on Mar 10, 2010 • Computers & Internet
tip
General Keyboard Shortcuts, General Keyboard Shortcuts General Keyboard...
CTRL+C (Copy)
CTRL+X (Cut)
CTRL+V (Paste)
CTRL+Z (Undo)
DELETE (Delete)
CTRL+A (Select all)
tip
Windows XP Shortcuts
Copy. CTRL+CCut. CTRL+XPaste. CTRL+VUndo. CTRL+ZDelete. DELETEDelete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETECopy selected item. CTRL while dragging an itemCreate shortcut to selected item. CTRL+SHIFT while dragging an itemRename selected item. F2Move the insertion point to the beginning of the next word. CTRL+RIGHT ARROWMove the insertion point to the beginning of the previous word. CTRL+LEFT ARROWMove the insertion point to the beginning of the next paragraph. CTRL+DOWN ARROWMove the insertion point to the beginning of the previous paragraph. CTRL+UP ARROWHighlight a block of text. CTRL+SHIFT with any of the arrow keysSelect more than one item in a window or on the desktop, or select text within a document. SHIFT with any of the arrow keysSelect all. CTRL+ASearch for a file or folder. F3View properties for the selected item. ALT+ENTERClose the active item, or quit the active program. ALT+F4Opens the shortcut menu for the active window. ALT+SPACEBARClose the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4Switch between open items. ALT+TABCycle through items in the order they were opened. ALT+ESCCycle through screen elements in a window or on the desktop. F6Display the Address bar list in My Computer or Windows Explorer. F4Display the shortcut menu for the selected item. SHIFT+F10Display the System menu for the active window. ALT+SPACEBARDisplay the Start menu. CTRL+ESCDisplay the corresponding menu. ALT+Underlined letter in a menu nameCarry out the corresponding command. Underlined letter in a command name on an open menuActivate the menu bar in the active program. F10Open the next menu to the right, or open a submenu. RIGHT ARROWOpen the next menu to the left, or close a submenu. LEFT ARROWRefresh the active window. F5View the folder one level up in My Computer or Windows Explorer. BACKSPACECancel the current task. ESCSHIFT when you insert a CD into the CD-ROM drive Prevent the CD from automatically playing. Use these keyboard shortcuts for dialog boxes: To PressMove forward through tabs. CTRL+TABMove backward through tabs. CTRL+SHIFT+TABMove forward through options. TABMove backward through options. SHIFT+TABCarry out the corresponding command or select the corresponding option. ALT+Underlined letterCarry out the command for the active option or button. ENTERSelect or clear the check box if the active option is a check box. SPACEBARSelect a button if the active option is a group of option buttons. Arrow keysDisplay Help. F1Display the items in the active list. F4Open a folder one level up if a folder is selected in the Save As or Open dialog box. BACKSPACE If you have a Microsoft Natural Keyboard, or any other compatible keyboard that includes the Windows logo key and the Application key , you can use these keyboard shortcuts: Display or hide the Start menu. WIN KeyDisplay the System Properties dialog box. WIN Key+BREAKShow the desktop. WIN Key+DMinimize all windows. WIN Key+MRestores minimized windows. WIN Key+Shift+MOpen My Computer. WIN Key+ESearch for a file or folder. WIN Key+FSearch for computers. CTRL+WIN Key+FDisplay Windows Help. WIN Key+F1Lock your computer if you are connected to a network domain, or switch users if you are not connected to a network domain. WIN Key+ LOpen the Run dialog box. WIN Key+ROpen Utility Manager. WIN Key+U accessibility keyboard shortcuts: Switch FilterKeys on and off. Right SHIFT for eight secondsSwitch High Contrast on and off. Left ALT+left SHIFT+PRINT SCREENSwitch MouseKeys on and off. Left ALT +left SHIFT +NUM LOCKSwitch StickyKeys on and off. SHIFT five timesSwitch ToggleKeys on and off. NUM LOCK for five secondsOpen Utility Manager. WIN Key+U shortcuts you can use with Windows Explorer: Display the bottom of the active window. ENDDisplay the top of the active window. HOMEDisplay all subfolders under the selected folder. NUM LOCK+ASTERISK on numeric keypad (*)Display the contents of the selected folder. NUM LOCK+PLUS SIGN on numeric keypad (+)Collapse the selected folder. NUM LOCK+MINUS SIGN on numeric keypad (-)Collapse current selection if it's expanded, or select parent folder. LEFT ARROWDisplay current selection if it's collapsed, or select first subfolder. RIGHT ARROW
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
