Computers & Internet Logo
Posted on Mar 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Guide is there a guide for the MS basic keyboard 1.0A listing short cuts etc?
Anonymous
Level 2:
Sergeant:
  • Expert 258 Answers
  • Posted on Mar 29, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
258
Questions
0
Helped
115773
Points
926
General keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+C (Copy)
  • CTRL+X (Cut)
  • CTRL+V (Paste)
  • CTRL+Z (Undo)
  • DELETE (Delete)
  • SHIFT+DELETE (Delete the selected item permanently without placing the item in the Recycle Bin)
  • CTRL while dragging an item (Copy the selected item)
  • CTRL+SHIFT while dragging an item (Create a shortcut to the selected item)
  • F2 key (Rename the selected item)
  • CTRL+RIGHT ARROW (Move the insertion point to the beginning of the next word)
  • CTRL+LEFT ARROW (Move the insertion point to the beginning of the previous word)
  • CTRL+DOWN ARROW (Move the insertion point to the beginning of the next paragraph)
  • CTRL+UP ARROW (Move the insertion point to the beginning of the previous paragraph)
  • CTRL+SHIFT with any of the arrow keys (Highlight a block of text)
  • SHIFT with any of the arrow keys (Select more than one item in a window or on the desktop, or select text in a document)
  • CTRL+A (Select all)
  • F3 key (Search for a file or a folder)
  • ALT+ENTER (View the properties for the selected item)
  • ALT+F4 (Close the active item, or quit the active program)
  • ALT+ENTER (Display the properties of the selected object)
  • ALT+SPACEBAR (Open the shortcut menu for the active window)
  • CTRL+F4 (Close the active document in programs that enable you to have multiple documents open simultaneously)
  • ALT+TAB (Switch between the open items)
  • ALT+ESC (Cycle through items in the order that they had been opened)
  • F6 key (Cycle through the screen elements in a window or on the desktop)
  • F4 key (Display the Address bar list in My Computer or Windows Explorer)
  • SHIFT+F10 (Display the shortcut menu for the selected item)
  • ALT+SPACEBAR (Display the System menu for the active window)
  • CTRL+ESC (Display the Start menu)
  • ALT+Underlined letter in a menu name (Display the corresponding menu)
  • Underlined letter in a command name on an open menu (Perform the corresponding command)
  • F10 key (Activate the menu bar in the active program)
  • RIGHT ARROW (Open the next menu to the right, or open a submenu)
  • LEFT ARROW (Open the next menu to the left, or close a submenu)
  • F5 key (Update the active window)
  • BACKSPACE (View the folder one level up in My Computer or Windows Explorer)
  • ESC (Cancel the current task)
  • SHIFT when you insert a CD-ROM into the CD-ROM drive (Prevent the CD-ROM from automatically playing)
  • CTRL+SHIFT+ESC (Open Task Manager)
Dialog box keyboard shortcuts loadTOCNode(2, 'moreinformation'); If you press SHIFT+F8 in extended selection list boxes, you enable extended selection mode. In this mode, you can use an arrow key to move a cursor without changing the selection. You can press CTRL+SPACEBAR or SHIFT+SPACEBAR to adjust the selection. To cancel extended selection mode, press SHIFT+F8 again. Extended selection mode cancels itself when you move the focus to another control.
  • CTRL+TAB (Move forward through the tabs)
  • CTRL+SHIFT+TAB (Move backward through the tabs)
  • TAB (Move forward through the options)
  • SHIFT+TAB (Move backward through the options)
  • ALT+Underlined letter (Perform the corresponding command or select the corresponding option)
  • ENTER (Perform the command for the active option or button)
  • SPACEBAR (Select or clear the check box if the active option is a check box)
  • Arrow keys (Select a button if the active option is a group of option buttons)
  • F1 key (Display Help)
  • F4 key (Display the items in the active list)
  • BACKSPACE (Open a folder one level up if a folder is selected in the Save As or Open dialog box)
Microsoft natural keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • Windows Logo (Display or hide the Start menu)
  • Windows Logo+BREAK (Display the System Properties dialog box)
  • Windows Logo+D (Display the desktop)
  • Windows Logo+M (Minimize all of the windows)
  • Windows Logo+SHIFT+M (Restore the minimized windows)
  • Windows Logo+E (Open My Computer)
  • Windows Logo+F (Search for a file or a folder)
  • CTRL+Windows Logo+F (Search for computers)
  • Windows Logo+F1 (Display Windows Help)
  • Windows Logo+ L (Lock the keyboard)
  • Windows Logo+R (Open the Run dialog box)
  • Windows Logo+U (Open Utility Manager)
Accessibility keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • Right SHIFT for eight seconds (Switch FilterKeys either on or off)
  • Left ALT+left SHIFT+PRINT SCREEN (Switch High Contrast either on or off)
  • Left ALT+left SHIFT+NUM LOCK (Switch the MouseKeys either on or off)
  • SHIFT five times (Switch the StickyKeys either on or off)
  • NUM LOCK for five seconds (Switch the ToggleKeys either on or off)
  • Windows Logo +U (Open Utility Manager)
Windows Explorer keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • END (Display the bottom of the active window)
  • HOME (Display the top of the active window)
  • NUM LOCK+Asterisk sign (*) (Display all of the subfolders that are under the selected folder)
  • NUM LOCK+Plus sign (+) (Display the contents of the selected folder)
  • NUM LOCK+Minus sign (-) (Collapse the selected folder)
  • LEFT ARROW (Collapse the current selection if it is expanded, or select the parent folder)
  • RIGHT ARROW (Display the current selection if it is collapsed, or select the first subfolder)
Shortcut keys for Character Map loadTOCNode(2, 'moreinformation'); After you double-click a character on the grid of characters, you can move through the grid by using the keyboard shortcuts:
  • RIGHT ARROW (Move to the right or to the beginning of the next line)
  • LEFT ARROW (Move to the left or to the end of the previous line)
  • UP ARROW (Move up one row)
  • DOWN ARROW (Move down one row)
  • PAGE UP (Move up one screen at a time)
  • PAGE DOWN (Move down one screen at a time)
  • HOME (Move to the beginning of the line)
  • END (Move to the end of the line)
  • CTRL+HOME (Move to the first character)
  • CTRL+END (Move to the last character)
  • SPACEBAR (Switch between Enlarged and Normal mode when a character is selected)
Microsoft Management Console (MMC) main window keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+O (Open a saved console)
  • CTRL+N (Open a new console)
  • CTRL+S (Save the open console)
  • CTRL+M (Add or remove a console item)
  • CTRL+W (Open a new window)
  • F5 key (Update the content of all console windows)
  • ALT+SPACEBAR (Display the MMC window menu)
  • ALT+F4 (Close the console)
  • ALT+A (Display the Action menu)
  • ALT+V (Display the View menu)
  • ALT+F (Display the File menu)
  • ALT+O (Display the Favorites menu)
MMC console window keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+P (Print the current page or active pane)
  • ALT+Minus sign (-) (Display the window menu for the active console window)
  • SHIFT+F10 (Display the Action shortcut menu for the selected item)
  • F1 key (Open the Help topic, if any, for the selected item)
  • CTRL+F10 (Maximize the active console window)
  • CTRL+F5 (Restore the active console window)
  • ALT+ENTER (Display the Properties dialog box, if any, for the selected item)
  • CTRL+F4 (Close the active console window. When a console has only one console window, this shortcut closes the console)
3answers
3answers
No problem. Just want to know what the F-keys (top of keyboard) are used for?
The F keys are function keys. They are basically shortcuts to common functions such as F1 in most applications will open a Help screen. Most browsers use F11 or F12 to go to Full Screen. Most of the keys have no function assigned to them. Also, when booting up, pressing and holding F5 will provide boot options such as Safe Mode to diagnose problems.
1helpful
I am the new user, Kindly support me with out charging users guides on how to use ms word easily with short cut keys
Open up Word, click on Help >> MS Office Word Help and a whole bunch of online solutions will appear on the right side. Have fun.
For example:
About shortcut keys
You can quickly accomplish tasks you perform frequently by using shortcut keys - one or more keys you press on the keyboard to complete a task.
For example, pressing CTRL+B changes the selected text to bold, just as clicking Bold on the Formatting toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, press ALT and then SHIFT+F10.) or selecting Bold in the Font dialog box (Format menu) changes the selected text to bold.
Printing a list of shortcut keys
If you frequently refer to the Help topics that list shortcut keys, you may find it helpful to keep a printed copy of those topics. In Help, locate the topic you want, and then click Print .
You can also run a macro (macro: An action or a set of actions that you can use to automate tasks. Macros are recorded in the Visual Basic for Applications programming language.) that creates a list of the current shortcut key assignments, and then print the list.
On the Tools menu, point to Macro, and then click Macros.
In the Macros in box, click Word commands.
In the Macro name box, click ListCommands.
Click Run.
In the List Commands dialog box, click Current menu and keyboard settings.
Click OK.
On the File menu, click Print.
Customizing shortcut keys
You can customize shortcut keys in Microsoft Word by assigning shortcut keys to commands that do not already have them or by removing shortcut keys you don't want. If you don't like the changes you make, you can return to the default shortcut key settings at any time.
Using shortcut keys with different keyboard layouts or Word as your e-mail editor
Shortcut keys mentioned in the Help topics, menus, and dialog boxes refer to the U.S. keyboard layout. Keys on other layouts may not correspond exactly to the keys on a U.S. keyboard. If the language of the keyboard layout you are using doesn't match the language you set for Microsoft Word or Word Help, you may have to make adjustments when using shortcut keys or change your keyboard layout.
If you are using Word as your e-mail editor, some of the shortcut keys listed may not be available or may produce different results.
What is the use of the ms word?
Hi Good day!!
What can you use MSWORD for?
Many organisations now use computers to produce and organise written material, correspondence, membership lists and so on. This guide deals with the most common programme, MSWORD, that is used on most computers. It is written for people who have not used the programme before and has very basic information about the keyboard and MSWORD. If you have taught yourself to use MSWORD, it may also be useful to you.
Your MSWORD programme is called a word-processing package. This means that it is useful for typing and storing letters, articles and anything that consists mainly of words. It is basically a fancy typewriter with a built in filing-system.
The more you use your computer the more you will learn about what it can do. This guide contains a few basic things to help you get started.
If you have not used a computer much, print the next section out and look at your keyboard and MSWORD programme with it. Try to do everything as you read it.
2helpful
How to create short cut keyboard keys in ms-excel ( if we insert hyperlink in one cell ,with out clicking that cell how to operate that link with the help of key board keys)
I think it made already all the shortcut keys in keyboard and the problem is on how. This short cut keyboard keys in Microsoft Excel is definitely defaulted by the problem Excel and you can change it.
To see all the listing, here is the link.
Open this link:
www.yboyandrei.com/shortcutexcel
If i am helpful to you, please rate me.
Thank you.
Yboyandrei
Visual basic
Read the MSDN articles on the MS Access in question, paying attention to the version of Visual Basic recommended also.  Not a lot to do with Yahoo! 4D Soft Scroll Mice, is it!?
Keyboard command not working
The file that contains your keyboard short-cuts is acad.PGP. Find our where this file isand then use the OPTIONS command to make sure your PGP file location is listed correctly.
Tip: you can open this file with notepad. You will see how it is organized and following the same pattern you can add your own short-cuts and/or change the ones you already have.
6helpful
4answers
Short keys of MS Excel
short key for minimize word exel window?
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
