You may have two settings to change; make sure that your laptop has its external VGA turned on. You may have to access the CMOS setup or choose an external monitor from the Control Panel - Display settings.
On your TV, you will have to change the input selection which is probably set for 'Cable' now.
You didn't mention the model number of your set so can't check which verbiage is available through your menu.
Once you have found the input selection section of the TV menu, if VGA is not specifically mentioned, just have material set up on your laptop (movie or similar) and step through the possibilities - slowly - so your set has a chance to see if signal is available from the selected input.
If it is still telling you 'no signal,' your laptop may still not be outputting anything to the TV.
