All channels on my tv are black and white but when i use my xbox the colour is fine. would it be the aerial signal that is the problem. I have an ALBA 26 LCD26880H DF, IT'S 10 MONTHS OLD.
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range. The signals for BBC and ITV are among the strongest ones broadcast. If they are now at a point on the aerial's range where they are too strong for the TV then the tuner will over-saturate. The result is the same as no signal.
Have a look online for a Variable Signal Attenuator. It's a device that can be added to a aerial signal cable just before it goes in to the tuner. The adjuster allows the signal level to be reduced. Watch the TV's signal quality and signal level displays if it has them. As signal level (power) reduces you'll actually see signal quality increase. If you go too far then quality will start to go down again. The optimum point is where quality is highest.
Sounds like a problem with the video output signal, or a change in the video settings on the device, go to your XBox configuration and make sure the video is set to NTSC.
I'm assuming here that this tv is being used for analogue reception because on digital you either get a perfect picture or when the signal is weak enough, nothing at all (common when trying to use rabbits ears or in poor reception areas). Assuming analogue then, when the signal is weak (grainy or snowy picture) the colour (called chroma) is automatically turned off because grainy colour is unwatchable. This is normal. Solution, a better aerial to provide a stronger signal.
Ok, if all you did was remove the vcr out of the circuit and put the aerial directly to the tv and now the color will not come in. That means your signal is not strong enough to provide a good picture. Some new model tvs have weaker tuners compared to older model tv and vcr tuners causing them to have weak snowy or black and white picture. The idea being most newer tvs are designed for cable or satellite hd use not for aerial use. What you wear doing before was amplifying the signal by running it thru the vrc first then viewing the output on the tv. Get another vcr or amplify the signal with an signal amplifier.
Is your outdoor aerial a proper freeview aerial and are you in a strong or weak signal area.You can check here:http://www.stevelarkins.freeuk.com/freeview_digital_tv.htm Also check your connections as the coax may be shorting with the braid or a bad connection.once checked try ordinary channels on upstairs tv and if ok retune all your digital channels. This can be due to a few problems.Firstly make sure your aerial is
pointing in the right direction as beam aerials attenuate(disregard)
signals which are not pointing directly at the aerial. make sure you are using good quality 75ohm cable i.e rg6 and connections are good and not shorting out. The length of run of the cable will also affect the signal as will any splitters or joins in the cable. If
you know the signal is good in your area then it will be down to the
aerial,cable terminations ,aerial position or a combination of these. If
the signal is poor you can either...Buy a high db gain arial which will
amplify the signal and or a masthead preamp which will again boost the
signal. please note that if your aerial is not pointing in the
correct direction then any boosting of a bad signal i.e ghosting...will
only make it worse. try starting from aerial direction then connections then a high gain aerial and or booster.
most likely the problem is due to a "lock up" you need to reset the system, unplug the set, and look in the back panel (I am assuming it is a digital (flat screen tv?) for a small (usuall) red nipple, again making sure the power is unplugged, depress the nipple with a bll point pen for about 5 seconds, wait a few minuets, and plug the set back in, you will most likely need to go to your menu for set up again, but you will be starting with a clean slate (so to sleak) and the tuner should then correctly pass the signal though
It is possible that the reason for the black & white as well as lines across the screen is weak, defective or wrong oriented antenna. If you are hooked up to cable, then it should not be a problem as you can call for service; if on the other hand you are using aerial antenna, you can try to: reorient or adjust the direction to where the antenna is pointed until the reception improves, check the lead in wire (cable or flat) for any breaks or shorts or loose connection, check/clean the connection of the antenna elements to the cable/flat wire, replace your aerial/cable as may be deemed fit and needed.
A couple of questions pls if the above does not solve your problem: when receiving from aerial, is the picture full vertically? are you also having problem with sound? If yes, where was the TV bought and where is it being used now? If no, is the image snowy and some channels/stations are better than the others? Good luck and pls post back how things turn up or further information. kind regards.
