Having worked for a consumer electronics company we had a trick that helped in many occasions. You can give it a bash and see if it helps.
Plug the TV directly into the wall socket and turn the power at the wall off. Then if your TV has any power buttons other than the standby button turn it off. Now hold the standby button on the TV in for 30 seconds. After that turn power back on and see if it helps. this works about 30-40% of the time. If nothing happens a repair or replacement will be called for.
Seems there is a short in the board caused by the instant power outage. So it is necessary to open the set to have a view. It seems possible there is a damage on the drivers on the power board to the lcd panel. You will need to trace by checking for short , check for components heating - since the power is tripping due to the short which makes it feedback it as a protection to cut off.
Remove power leads to suspected section to confirm as the power will build up. You will need some experience to work by tracing if not please do not tamper but get help.
