20 Most Recent
Hitachi 42PD7200 42 in. HD-Ready Plasma Television Questions & Answers
My Hitachi PD7200 plasma TV won't switch on. I've
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
How do I simply turn on the t.v woth the remote?
First- make sure the remote has good batteries and the batteries are in the correct orientation- positive "+" to positive, negative "-" to negative. It may be your remote batteries are used up. You won't believe how many times I find this during my Handyman visits to customers.
Assuming your remote is already coded for your particular TV all you need to do is:
Press the "power" or "on" button of the remote. If you don't have a remote "power/on" button then simply press the "TV" button on the remote. Your TV should now be on now.
Note: most remotes that come with the TV are already coded for it so you shouldn't have to enter a 3 or 4 number code particular to that brand of TV. You may have a "Universal Remote" which is a generic remote that works with many TV brands so they need to be coded to communicate to a certain model. Read the TV Installation/Owners Manual to operate the remote.
Dust inside screen
You would have to pull the case apart. depending on your tv you may also have to remove the lcd panel.
TV Totally Dead
If you wish to get more details, surf the
following link. There are over two thousand and four hundred posts. All are
related to television and other domestic electronic equipment service help. You
can get a solution there. Type in the brand name to your device to its search
box, can be located at the top right of the display window. It will make search
easy. More than Nine Lakh viewers cannot be wrong.
Hitachi LCD TV Dead
There is a internal fuse on the power supply board. When you plug in the set, does the standby light come on?
Hitachi lcd 42in
Either from Hitachi customer service (online) or GOOGLE the model number with "manual".
What is the tv code
what you will want to do is go into the users guide and find the reset factory defaults option usually it involves holding a button or two while starting the device however are sometimes very different
hope this helps
Robb
I can't find UHF channle 36
Turn plasma to analoque tv tuner auto search while xbox is connected and turned on. Auto tune will pick up uhf 36 channel .Flick chanelstill xbox chanel is viewable
