D-Link DSL 500 (DSL-500) Router Logo
A
Anonymous Posted on Feb 16, 2006
RFC support Does the DSL-500 support RFC?
Anonymous
Level 2:
Novelist:
  • Expert 196 Answers
  • Posted on Feb 16, 2006
Anonymous
Expert
Level 2:
Novelist:
Answers
196
Questions
Helped
106858
Points
441
The DSL-500 supports RFC-1483, 1577, 2364, and 2516.
My samsung infuse is showing an internal server error 500 and i cant access the net
I really don't know what to do next, i suppose the easiest solution is to forget my money and stop using paypal any more as i think that I am not getting anywhere answering question after question and getting no further forward. thank you.
3helpful
2answers
Server does not support RFC 5746, see CVE-2009-3555 What does it mean and what should I do?
RFC is a Remote Function Call and CVE is Common Vulnerabilities and Exposures. Since RFC is commonly used for server exploitation via viruses, most servers turn that function off, resulting in an error message like you reported.
While this may be a legitimate function call, this often means that your system has been compromised by a virus or malware. Run a reputable virus and malware scanning tool, like this one.
You can read more about your error message here.
What do you mean by RFC 802.1
RFC is Request For Comments on network protocols of all types.
How can i make apassword on my dsl
go here http://www.portforward.com/guides.htm and then got to wireless security guide
I have been getting terrible download speeds. I am with telus and there cheapest plan offers speeds of a little over 200 kbps. I am getting about 60. Is this the router or them?
Hi! your modem is a dlink dsl 300, if the modem is connected directly to your computer and you are only getting a speed of 60kbps..there is a chance that there is a problem with the modem.
this is the feature of ur modem:
Features
  • ANSI T1.413 issue 2 (Full rate DMT over analog POTS)
  • G.dmt (ITU-T G.992.1)
  • G.lite (ITU-T G.992.2)
  • G.hs (ITU-T G.994.1)
  • G.lite ADSL: Downstream data rate up to 1.5Mbps. Upstream data rate up to 512Kbps.
  • G.dmt: Downstream data rate up to 8Mbps. Upstream data rate up to 864Kbps
  • Supports G.hs, a handshaking protocol at start-up to negotiate and identify the operating mode for the DSL
  • Supports a wide range of DSLAM's for inter-operability
  • Complies to the T1.413 issue 2 standard (includes cable gauges like 24AWG (0.5mm) and 26AWG (0.4mm))
  • RFC 1483 IP over ATM
  • RFC 1483 Ethernet over ATM
  • Supports bridging/DHCP, classical IP over ATM, PPP over ATM, and Embedded PPP over Ethernet
  • 1 RJ-11 port for ADSL connection
  • 1 RJ-45 port for 10 BaseT Ethernet LAN connection
  • 1 Console (RS-232/DB9) port for local configuration
  • SNMP management agent base MIB-enables other processes to provide statistics and other information to remote management applications
  • TFTP : The built-in Trivial File Transfer protocol provides firmware upgrade and configuration backup and restore
  • Telnet provisioning
I this modem is supplied by telus you have to inform them about it so that they can replace this modem right away... and this is a discontinued product from dlink.
Modem
Technical Specifications AAL and ATM Support
VCI 0-65535 address range
VPI 0-255 address range
AAL5 support
Bridging
IEEE 802.1.d Transparent Learning Bridge (dynamic learning of up to 255 addresses)
Spanning Tree support
Certifications
FCC Part 15, Class B
CE certification
Connectors
DSL interface: RJ-11 or RJ-45 (Europe)
Ethernet interface: RJ-45
USB Type B interface (5200, 5500 series)
Diagnostic LEDs
Power, DSL, Activity, Ethernet status; USB status (5200, 5500 series)
Management
Intuitive, Web-based GUI management access
SNMP support
Comprehensive hardware diagnostics
Media Interface
RJ-11 or RJ-45 (European) DSL WAN connection
10/100Base-T RJ-45 Ethernet LAN connection
USB Type B LAN connection (5200, 5500 series)
Power
12V power supply included, 700ma max. 5400/5500 - 12 VDC, 1000ma max.
Routing
DHCP server/DHCP client
Network Address Port Translation (NAPT)
Network Address Translation (NAT)
Packet filtering
RFC 2364 Point-to-Point Protocol over ATM PVCs (PPPoA)
RFC 2516 Point-to-Point Protocol over Ethernet (PPPoE)
RFC 2684 (formerly 1483) Bridged Ethernet and routed encapsulation Routing
Standards Compliance
IEEE 802.3
USB 1.1 T1.413 issue 2 G.992.1 (G.DMT) G.992.2 (G.Lite)
Convert
cant open this address
http://192.168.1.1
what about solution
Thank you
E.F. Speedstream 5871 router
You may be able to use these with "standard" DSL, which generally does require PPPoe (a username and password, basically). But you'd certainly need to have an ISP providing DSL service, the correct wiring drop to the device, and your DSL provider would need to support this particular device on their network.
These are not routers, per se, they are really just DSL modems.
Resolving installation problems with GrandTec EyeSeeAll RFC-3000 webcam
I WANT TO INSTALL A ZENITH WWEB CAM PUT DONT HAVE TH SOFTWARE HELP PLZ....
Finding the user name
You must use the RS-232 serial cable using terminal emulation software such as Microsoft HyperTerminal. Connect the cable from your computer to the console port on the DSL-500 or DSL-504. Step 1: Go to Start>Programs>Accessories>Communications>Hyperterminal. Step 2: Enter a name for your connection and choose the default icon selected. Step 3: Select a COM port (usually 1 or 2) and click OK. Step 4: The terminal parameters will need to be set to as follows: Step 5: At the command prompt type isfs cat inituser and press enter. You will now see the username and password.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
