Televison & Video Logo
Posted on Sep 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
People have red cheeks, red under eyes also. They have green hair. There are ghost images around their faces and sometimes they have two faces, one partially overlapping the other. The picture is blurry and sometimes it shakes.
  • stircrazy15 Sep 18, 2008
    I finally received the correct STKs. My mistake, not the vendor. I had them installed by a guy at work who is an expert in this field. I re-installed the board and powered the television. I now have three distinct pictures colored red, blue and green with some white mixed in. This is a Hitachi TV with magic focus. When the magic focus button is depressed it indicates it is performing the function but when it completes the picture quality does not change. I have tried the manual method but the picture quality is no better after completion. Overall, the picture quality is poorer now than it was before the STK-392s replacement.
    I have tried both auto and manual convergence as already indicated. The STK-392 110 and STK-392 150 have been replaced. What other ICs need replaced?
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Sep 18, 2008
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957635
Points
33084
You need to perform static and dynamic convergence adjustments in your hitachi tv by going into service mode. It is very technical adjustments and if you now how to perform, then go ahead.
Here is procedure how to go into service mode...
1. TV turned off
2. Press 'Power' and 'Input' buttons on the TV for more than 3 seconds..
Now you are in service mode.
The letter P indicates picture and A indicates audio.
4. Use the 'Menu up or down' on the remote to select the item.
5. Write down the old value of the item before changing.
6. Use the 'Menu left or right' to change the data.
  • Anonymous Sep 18, 2008
    Note: before adjust any data in service mode, please take note or write down its value because you might need to recall previous or old data there.
Anonymous
Level 3:
President:
  • Master 1,263 Answers
  • Posted on Sep 03, 2008
Anonymous
Master
Level 3:
President:
Answers
1263
Questions
Helped
683182
Points
4577
You need to go into your set up menu and select convergance. adjust it and this should help. if it doesn't hen it is a faulty convergance ic module and you will have to contact a local repair service and either replace them yourself(only if you have electronics experienc) or have them replaced for you.. please rate this.......thanks
    you indicated that you have an auto focus feature. it is obvious that your focus apeture is not doing what it's suppose to even though the the tv is telling you it is. with the auto focus(magic focus) igt works in conjunction with the convergance. this is a motherboard fault and chances are you need to have someone with the experience(your buddy forinstance check the mother board out.) without being hands on it would be hard for me to pinpoint the exact nature of the problem. please changre the rating to helpful. i'm in the ball park as far as giving you options that qualify... thanks
Anonymous
Level 3:
Master:
  • Master 521 Answers
Anonymous
Master
Level 3:
Master:
Answers
521
Questions
0
Helped
163038
Points
1218
Its the problem of STK ics in the convergence board just get it replaced.the tv will work properly for sure.
it will not be too costly.do not try to do it your self with out technical knowledge.it will be fine.nothing to worry.the tv is perfect just change the STK ics.
pls do rate the solution
thanks.
regards.
fixya expert team
Ginko
Level 3:
  • Televison & ... Master 19,396 Answers
Ginko
Level 3:
Answers
19396
Questions
25
Helped
8078175
Points
55462
It is a convergence problem.
  • Ginko
    Ginko Sep 03, 2008
    You need to have convergence setup done, it is likely that one of the integrated circuits (STKs) on convergence board has blown, and need to be replaced.
What means physical features
lots of times in describing humans this term is used to prompt the user into better describing the exact feature's or shape of the face and body , an example would be ( lite brown hair , tall /thin build , green eyes, scar on left cheek ) etc .
I have a Sony TV model KDL-40BX412. There is a red ghost. Sometimes it is green. The longer the TV is on, the distance between the image and the ghost decreases, but never disappears.
Contact the authorized service centre for Sony. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
1helpful
After replacing the bulb on my 60 by, I have red and green hosting around images.
I have the same problem. I just replaced my 9 year old lamp with a new one from a seller on Amazon (for only $88) but the ghosting and red/green misconvergence is still apparent, especially on standard definition DVDs played on a BLU-ray player through the Sanyo projector.
I found where a poster on an Australian board wrote that he was able to make adjustments using a service manual to get the red and green LCDs back in alignment. He describes it here:
http://www.dtvforum.info/lofiversion/index.php?t53093.html
1helpful
Samsung HCN4226W "image pinching"
The convergence IC has gone out and is located on the Main bd or the Power supply bd depending on the specific model and must be replaced and a Full convergence alignment must be performed to return your tv to a watchable condition. Only a Samsung trained tech can do this.
Blue Ghost
you will need to replace 2 stk ic [ parts ] after that the technician will have to realign the picture, sometime also some resistors get bad along with one or 2 fuses
Ghost red image
If you are connecting via HDMI, try either getting the firmware upgrade from the Philips website or switching to Component (Red, Green and Blue) cables.
2helpful
Color Issues with red ghosts on screen
The suggestions listed would be relevant for 'Ghosting' by itself, however you mentioned you tried to use the crosshairs to line up the images4.gif, which implies convergence - red/green/blue image separation and/or distortion. NONE of the solutions mentioned were anywhere close to the fix for this problem - this us usually cut and dry; convergence circuit failure. Generally, STK ICs are used. (Common parts are STK392-010/020/040, STK392-110/120/150/180, etc.) Most times replacing BOTH of these chips will be enough, sometimes there will be a blown fusible resistor and/or burnt resistors near the chips themselves. If you don't implicitly know exactly what I'm talking about, don't attempt it - take it in to a repair shop. For in-shop repair, this would NOT exceed $250 (EVER) at our location, unless there was more damage done, which is a one in a hundred situation. Good luck!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Red and Green picture with ghost images
sounds like the high voltage transformer arc or one of the picture tubes arc causing the convergance ic to go bad
you can try to replace the IC heres a site to help:
but you still may have a arcing problem.
"muddy eyes"
I don't think the problem is the eyes. the problem comes because the focus of the scanner is not the same with film zone and films support, there is a one mm difference. You have to specify the good way in the driver.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
