Tip & How-To about Washing Machines
The possibilities are as follows:--
Check the Air gap device and
the Tube in the washing machine for leaking problem.
The air gap device is located
at the end of the black rubber hose that comes from the water-inlet valve. It’s
made of translucent plastic. If the air-gap components worn out or cracks, it
has to be replace.
Now if the Air gap device
checks out ok. Then the other possible part to be checked is tube.
The tube is connected between
the water-inlet valve and the air-gap. If it cracks or breaks, it can cause a
leak.
These will help. Thanks.
