Tip & How-To about Bunn CWTF 15-3 Coffee Maker
Lime builds up on the metal surfaces where the hot water cools down or evaporates, such as the sprayhead, the waterline to the sprayhead, the reservoir inlet, or the insides of the tank. the sprayhead and reservoir inlet buildup will restrict flow and extend brew time and may even not brew through all of the grounds. to fix:
1. remove the top of the brewer. the reservoir is right on top and the drain looks like a nut with a hole in it. lime will plug this up. using a deliming spring or even a philipshead screwdriver, push through and twist to get rid of the lime.
2. unscrew and remove the sprayhead and bore the lime out of the holes with a small flathead screwdriver or a paperclip.
3. if necessary, unscrew the reservoir drain nut, place it and the sprayhead in a cup of straight vinegar. for more stubborn lime, use CLR, but wash and rinse thoroughly.
4. if you have a deliming spring, push it through the outlet waterline to the sprayhead all the way past the 2 elbows and pull in and out, removing any lime buildup.
5. rinse parts, reassemble the reservoir, and brew a little without the sprayhead first to get rid of any loose lime. then put sprayhead on and run a test brew. if it brews short or too much, see tip for recallibrating
