Question about Bunn CWTF Coffee Makers & Espresso Machines
Warming plate and light stopped working on Bunn coffee maker
Warming plate is cold and light burnt out.
jasbo
  • Bunn Master
  • 2,239 Answers
Replace the switch
Posted on Jan 28, 2015
4 Related Answers
Kelley Hopper
  • 67 Answers
SOURCE: Warming plate boils coffee.
Make sure you are using the type of commercial coffee pot like the one in the picture. They don't have to have to be plastic with the metal bottom, they can be all glass. The commercial pots are heavy duty and usually disperse the heat well.
If you are using commercial pots the only solution without replacing the warmers is to put three pennies on the warmer and to put the pot on top of them. The pennies will get hot so don't forget and grab them but the pennies help to move the pot just a little way away from the direct heat.
Posted on Feb 09, 2008
Kelley Hopper
  • 67 Answers
SOURCE: bunn coffee maker
It sounds like you have a pour over model and the problem is the tank isn't full. Turn the machine off (or unplug it). Put a pot on the warmer like you are going to brew coffee. Pour clean cold water into the top until it starts coming out the sprayhead (above where the coffee grounds go). Now plug it in and turn on. Let it heat up then you can brew.
The way your machine works is that there is always about 2-1/2 pots of water in the tank. The water you pour in to make coffee is actually pushing the hot water in the tank out. So, if you don't fill the tank before using it, you may be hurting the heating element since it isn't totally submerged in water.
Posted on Oct 12, 2008
Anonymous
SOURCE: warmer stopped working
the coffee maker brews but the pot warming plate isn't hot
Posted on Nov 08, 2008
atbsmmom
  • 189 Answers
SOURCE: I have a Bunn NHB
If you will call customer service at 800-352-2866 with the model and date code, we will be happy to assist you with this issue.
Posted on Jan 18, 2011
Red light won't come on
Assuming your talking about the warming plate light, Google "bunn nhb warming switch" to search for replacements.
Apr 23, 2014 | Bunn NHB Coffee Maker
I have a Bunn coffee maker with date code of 401406. It is almost 4 years old and still brews perfectly. The warming plate does not heat up any longer so the coffee will not stay warm after it is brewed....
The manual for this coffee maker can be found at this link:
http://manualheaven.com/assets/bunn-nhbx-b-contemporary-coffee-maker-manual.pdf
While the manual does not contain repair instructions, it does have some troubleshooting tips to follow if your coffee is not staying hot.
May 04, 2011 | Bunn NHB Coffee Maker
Water wont heat. Warmer has no heat but light is on
Hello, One of the wires soldered to the underside of the warming plate had fell off due to poor soldering.The warming plate and the warning light are connected together with piggy back connectors so that is why the light is on even when the warmer is cold. Bye
Jul 03, 2010 | GE 106591 Coffee Maker
Need warming plate for Bunn Pour O Matic coffee pot
Due to UL regulations, warmer plates can't be sent out. However, you warmer plate can be repaired for a minimal charge. Please call customer service with the model and date code and we will be happy to provide you with the cost and address.
Nov 26, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn coffee maker
Oct 12, 2008 | Bunn NHB Coffee Maker
Warming tray too hot
You can either replace the warming element with a new one, or some people put 3 or 4 pennies on the top of the warmer tray. Don't laugh- this really does work!
Feb 08, 2008 | Bunn VPR Coffee Maker
Bunn UPR warmer too hot
Try connecting two elements in series. See if this keeps it hot enough. (One switch controlling both burners.) See if another brand of burner will fit in the hole. Check to see if the wattage is lower.
Feb 06, 2008 | APW Wyott Mr. Frank Hot Dog Broiler & Bun...
Warming Plate
actually the warming plate have heating element... they stop working only when the heating element gets open circuited or wire to that plate gets cut....
Jan 31, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Warmer not working
This would only applie to a newer modle. I can tell u this that if u contact the company by phone they will offer you a replacement at no charge to u.
Dec 22, 2007 | Bunn NHB Coffee Maker
Warmer stopped working
Nov 14, 2007 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
2,107 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
