Question about Bunn CWTF 15-APS Coffee Maker
Bunn cwtf adjust temperature - Bunn CWTF 15-APS Coffee Maker
Thomas Aldrin Nullas
    New Friend:
  • 128 Answers
U must locate the lock bottom to open and re- programs ur temp. settings...
Posted on Oct 02, 2014
4 Related Answers
EsWorld
Ernest R
  • 1618 Answers
SOURCE: adjusting temperature for bunn cwtf twin
Look for the black knob with the arrow and it might have a red paper tag attached, turn clockwise all the way, then back about 1/4 of an inch.
Posted on Jun 18, 2009
Anonymous
SOURCE: adjusting the temperature
Our Bunn VPR was delivering luke warm coffee. The problem was lime scale buildup on the heating element. I recommend using a cleaner such as Brew Rite or a vinegar solution. If it still does not heat properly, unplug and remove the heating element for cleaning. This corrected our problem.
Posted on Oct 05, 2009
EsWorld
Ernest R
  • 1618 Answers
SOURCE: installation of grommet on model cwtf 15 ( 1 lwr/2 upr pf
Which grommet, there are several on the bunn models, but the most commonly replaced one is the one for the P. stat. Remove the top panel there are 2 screws one in front and one in back, then lift the top 2 burners off machine that will give you access to the tank.
Posted on May 04, 2010
trewly617
  • 35 Answers
SOURCE: my bunn cwtf 15 wont put out hot water and the
If your ready light is on and your water is not warm... sounds like the thermostat is too low. Inside the front panel (behind the brew basket) there is a thermostat adjustment on the left-hand side. If you turn that up your ready light should shut off. You can then adjust the temp to your desired level. (194-200 degrees depending on roast, grind, etc...)
Posted on Sep 09, 2010
I need to ship a 3 burner BUNN CWTF 15-3. How do I drain the water out?
You can take the lid off and unscrew the nut that holds the water tray. Then take a 3/8 hose to siphon the water out of the machine.
Apr 17, 2013 | Bunn CWTF 15-3 Coffee Maker
My bunn cwtf 15 wont put out hot water and the ready light wont turn off dustain
Jun 14, 2010 | Bunn CWTF15-TC
Installation of grommet on model cwtf 15 ( 1 lwr/2 upr pf
Apr 30, 2010 | Bunn CWTF 15-2 (1 Top Warmer) Coffee Maker
Our Bunn CW series three burner is over filling. How to correct the problem??
needs service tech to adjust.
(Do it yourselfers can adjust the black knob down from 2.5 to about 2 mins. Digital timers have instructions in back of the front panel. CAUTION!! There is high voltage present. Pull out the plug! Safer to just have it serviced.)
Feb 03, 2010 | Bunn CWTF 15-3 Coffee Maker
Bunn cwtf15 coffee isn't hot enough the coffee brews @115 degrees
Adjust the thermostat, located behind the front panel, there will be a knob, turn all the way on then back about 1/4 turn.
Dec 07, 2009 | Bunn CWTF 15-TS Coffee Maker
Adjusting temperature for bunn cwtf twin
Jun 17, 2009 | Bunn VPR Coffee Maker
Adjusting the temperature
Bunn CWTF 15-APS Coffee Maker Logo
1,011 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
