Question about Bunn VPR Coffee Maker
The water gets hot and does not perk. There is no lime in the tank or tube and I filled it until it ran out. Is the water temp really crucial to make this work? I turned up the thermostat and saw bubbles on the fill side. It does not build pressure but water pours through easily when you overfill it.
Posted by goodmankelly on
Anonymous
    New Friend:
  • 91 Answers
Try using a bunn deliming spring.Remove sprayhead and run thru the brew tube all the way into the tank.If the water is hot the brew tube is partially blocked going into tank.
Posted on Jan 30, 2011
What would be a solution to correct the problem?
Hi
I'm assuming you are talking about a washing machine.
You posted this under Cars & Trucks?
I suspect there is an inline filter (coarse plastic mesh) in the standard fill line. It's probable blocked itself with the accumulated calcium in the water.
You could use CLR (Calcium Lime & Rust) solution to dissolve the calcium.
Or
Disconnect the hose and push a small snake device (curtain spring) through the hose until you find where the filter or obstruction is.
Good Luck
Calcium Lime and Rust Remover
Feb 23, 2016 | Cars & Trucks
Not enough hot water
Some hot water means upper element is good, reset button is pushed in and not tripped, overheating is not issue, wires connected at top of tank are probably good, and unit getting power, but not necessarily full power. Otherwise we have not ruled out anything else.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
Check for crossover.
http://waterheatertimer.org/Crossover.html
Check for leaks: turn off all taps and put ear against pipe.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 05, 2013 | Richmond 6E50-2 50-Gallon 4500-Watt...
Bought a hot water heater made by whirlpool for 2 weeks only had enough hot water to fill 1/4 of the tub then the water turned cold . They have replaced the hot water heater and still has same problem....
The down tube in the tank has fallen off or the hot and cold lines are reversed at the tank. I'm going to assume it is gas , if its electric you need to test the heating elements for continuity and temp settings. as well as the down tube in the top of the tank that sends the cold water feed to the bottom of the tank..
Mar 13, 2011 | Whirlpool Home
My bunn vlpf coffee maker the water tank is overheating to the point of steam is spewing fro the air release tube... I'm thinking thermostat ?
You are correct.Also check the tank for lime.By unplugging and removing top of machine (2) screws and remove fill basin.You can then remove your t-stat probe to check.If it is lime up you can crack off the lime and reinstall it in the tank.If limed up I would suggest de-liming.T-stat part# 4314.0001.
Jan 29, 2011 | Bunn VLPF Coffee Maker
The toilet isnt flushing and water is not filling into the cistern? (at the top) how do i fix this problem??
If I understand correctly, the tank that holds water is not filling up with water.
1) If this is the problem, then you need new toilet fill valve.
Or clean sediment out of existing fill valve by removing and soaking in CLR calcium rust lime.
To replace fill valve:
Look at water supply line coming into tank.
Supply line connects to fill valve.
Buy new fill valve at home center, hardware store, or walmart, or online.
There are two nuts connected to valve. Each nut has companion rubber washer
One nut & washer seal water supply line to tank.
Second nut & washer seal valve to tank.
2) If water tank is full of water, but water does not flow rapidly into bowl when you push flush lever, then your toilet is clogged with sediment.
To solve sediment problem when flush water will not flow rapidly into tank, then buy CLR calcium lime rust.
Pour CLR down into overflow tube located inside water tank.
Make a funnel by cutting off bottom of water bottle, or cut paper cup into a funnel.
Pour cup-full after cup-full of CLR into overflow tube until sediment and CLR are coming out all flush holes located under-rim on bowl.
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 22, 2011 | Home
My new percolator will not perk? Water gets hot but doesnt seem to rise to the top.
I had the same problem, and I figured it out. Read on, to see if this applies to you. This percolator was received as a present years ago, and I'm not sure it ever worked right. First, some info and background. The above comments about the heating element being clean to bare metal, while valid, did not work for me. I also read other posts suggesting the thermostat might be defective, which also did not seem to apply to my situation because the water is always hot enough at the end of the cycle, not boiling, but steaming hot enough for just about anyone. I deduced the problem to be with the actual perking process, not heat or heating element. A percolator should perk before the water is at drinking (HOT) temperature, and the perking action cools the water and prolongs the actual perking process. The problem I found was with the washer at the bottom of the tube, which is supposed to act like a 1-way valve. The washer, from the factory, was apparently too loose with almost a 1/4-inch or play, allowing hot water that would otherwise perk back into the water chamber, effectively making my percolator into a kettle. I used a stainless steel washer and an e-clip to tighten the washer against the holes on the lower umbrella-shaped flange so that there is just enough room to slide a feeler gauge or perhaps a couple of sheets of paper. Now the percolator works great, fantastic actually. Watching the coffee perk at the top in anticipation of a hot cup is entertaining, and with the stainless steel pot I have no worries about phytoestrogens leaching from plastics common in drip coffeemakers. See photo of my hack if it uploaded correctly. Its high res, so you may be able to download and zoom in. Enjoy! new-percolator-will-not-n1see0xg4iab1sfdaqlesvfh-4-1.jpg
Oct 18, 2010 | VillaWare Mini-Perk 5120-05 Coffee Maker
It seems to be perking correctly but stops and then starts to perk again and again, this continued until I unplugged it, and also the light to indicate it was done never came on
Your pot needs a keep warm element. the main element works ( perks and perks) The thermostat works ( it turns the main element on and off.) The pot goes on and off because the water is getting cold The problem is the keep warm element. The reason, your pot perk's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. Thanks and please ask if you need more help. Go to repairshack.com for the part. Ron
Sep 25, 2010 | Faberware 10-22 Cup Coffee Urn
Bunn perks coffee very slow?
This is generally an indication of a lime build-up in the water tubing. If you take off the sprayhead and insert the metal deliming tool into the water tubing all the way leaving out about 1-2 inches and twist it about 5-6 times, this should remove the lime deposits from the water tubing. Then flush out the machine with 2-3 decanters of water. If this doesn't fix the problem, then call customer service with the model and date code for further assistance.
Aug 01, 2009 | Bunn GR10 Coffee Maker
No heating and no hot water, my boiler won't fire up
If there is a hi-limit switch, maybe it's open, reset the switch, and monitor the temperature, if the temp. increases over the set temp. replace stat, and clean lime off from the tank, if does not have a filtering system
Apr 21, 2009 | Heating & Cooling
It fills the pot very slow - how do you clean it?
hello tigger, You should be able to get a ipe cleaning brush at a fish/pet shop. Then apply it somewhat like this http://www.youtube.com/watch?v=CJSh1f6KHWw
i look forward to your post.
Oct 30, 2008 | Bunn VPR Coffee Maker
Bunn VPR Coffee Maker Logo
145 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
