Question about Bunn CWTF15
CWTF15 WILL NOT STOP WATER FLOW WHEN POT IS MADE.
Water flow continues to run and will not stop when pot is full. Water flow will continue until second pot is filled?
Mark Cheong
    Master:
  • Bunn Master
  • 791 Answers
You should call your vendor for service on any commercial brewer. (Especially if it's on loan from them)
*** the following is for information only as all repairs should be performed by a qualified tech.***
The CWTF has a start switch activates the timer (analog or digital) board which turns on the water feed to the brew tank. This forces previously heated water out and sprayed over the ground coffee in the brew funnel. Coffee then drips into the decanter. Overfilling is caused by un-calibrated timer or interment timing.
* The timer comes in two types; Dial (old) and Digital. If it's the dial then a simple turn of the dial will make less or more water flow to decanter. You MUST re-brew (no coffee, but use funnel) into the decanter or pot that you plan to use. Don't mix up different size pots as the timer is only good for 1 setting. Turn dial and brew once to check. Keep checking with a brew after each adjustment. Do a final brew just to be sure.
* The digital timer is a bit more complicated to adjust. Sorry, too many switches and options to go into it here. Check Bunn.com for a manual (FREE download) on line. Several methods are listed. The fill and stop is the easiest one.
* If it does not adjust or won't keep the set time then. Replace the timer. Digital timers tend to be sensitive to electrical storms. Analog timers have a dial and are more tolerant of electrical surges.
* Check the water fill solenoid. Should be a definite click when activated. Water filling sound should be very clear.
* No water flow then check the water supply line if it's on.
* Final; this brewer needs service. Call your coffee vendor for advice.
Aloha, ukboy57
P.S. I'm assuming the brewer does eventually stop brewing. If water flows with no stopping then the fill valve is stuck open and needs to be replaced. Yes, others have mentioned to clean it but it will fail again and again. Better to replace.
Tip, Older timers usually are reliable. It may have been set for a larger decanter or pump pot. The pump pots come in 2.5L and 3L for the big boys. Decanters are 10 cup and standard 12 cup. Check your office as there may be an unused 3L pump pot in a cupboard that got put away for making "too much" coffee. Try a brew in this larger pump pot.
Posted on Jan 31, 2018
Edward Harris
    Scholar:
    New Friend:
  • 78 Answers
The coffee dispensing valve is stuck open. It may be due to Calcium deposits.
Descale the machine or manually clean the dispensing valve and the diffuser disc that unscrews to be removed. This diffuser is visible just above the coffee pot.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Posted on Oct 18, 2014
5 Related Answers
Anonymous
  • 42 Answers
SOURCE: It fills the pot very slow - how do you clean it?
there is also some chemical to flush thriufh a cycle called C.L.R. IT IS FOR CALCIUM LIME AND RUST ALOT OF HARD WATER DEPOSITS COME IN OUR DRINKINK WATERS.THE USE DISTILLED WATER AFTER YOU ARE FINISHED AND IT WILL NOT CLOG AS FAST
Posted on Nov 12, 2008
Anonymous
  • 124 Answers
SOURCE: The water starts flowing for about a minute then
This sounds like normal operation of this type of unit.
Look at the brew funnel. is coffee coming out of it all the time during the brew cycle?
If so, then what you are hearing is the water supply solenoid cycling.
Posted on Jan 03, 2010
Anonymous
  • 12 Answers
SOURCE: I have a Bunn CWTF15. Water does not fill the
If u haven't cleaned it out using 3/4 vinegar to 1/4 water, some times this will happen. after running this thru ur coffee maker, (u won't believe the junk that comes out), then run full pots of water to rinse out (2x's). This should help it perform better.
Posted on Sep 12, 2010
Anonymous
  • 23 Answers
SOURCE: cleaned my pot but the water is running very slow.
First thing to check is that there is no blockage in the funnel. Next thing is check the spray head and make sure that it is not limed up. After removing the funnel there will be a round silver head that screws in above the funnel, it can be removed by hand but usually you need a pair of channel locks. If so you can clean the spray head with a wire brush. Also if that is not an issue you can purchase a deliming spring from http://www.google.com/imgres?imgurl=http://ecx.images-amazon.com/images/I/21IeXJoqjnL._SL500_AA300_.jpg&imgrefurl=http://www.amazon.com/Bunn-Commercial-Deliming-Spring/dp/B0032QNRH2&usg=__mJkJExy1qExfrZEEbtxW6EAQGSw=&h=300&w=300&sz=5&hl=en&start=4&zoom=1&itbs=1&tbnid=tHf1BPtEJIafsM:&tbnh=116&tbnw=116&prev=/images%3Fq%3Ddeliming%2Bspring%26hl%3Den%26gbv%3D2%26tbs%3Disch:1
WIth the deliming spring you need to remove the spray head and simply run the spring through the hole til you hit the water in the tank and pull it back and forth about 4 or 5 times. Also something siple make sure there is only one coffee filter it is easy to put two in. Hope this helps.
www.midstatebeverage.com
Posted on Dec 01, 2010
Anonymous
  • 91 Answers
SOURCE: WE HAVE A BUNN VLPF SERIES COFFEE MAKER. WHEN YOU
Sounds like your timer part #32400.0002.This is the new type timer which replaces the dial timer.Another thing is does this happen when you turn on the on/off switch? I would also check your liquid level probe in top of tank.Always a possibility bad liquid level board.If it only does this when you push the brew button the timer is bad.
Posted on Feb 11, 2011
I just bought the Bunn VLPF series, double burner. My other Bunn coffee pot had the option of make a half pot of coffee but this one does not Is there a tip to follow for half a pot?
Sorry this brewer is usually set up for a full pot brew. I have reset this for a small (but not half) pot brew as the customer wanted to use a metal carafe (with their own logo). I also tried once to get it to half pot brew but it can get tricky if you actually brew twice to get a full pot (in the same pot).
* there is a siphon action that starts once the boiler tank gets filled to a certain point. From that point it will continue to flow until the boiler is emptied to the level that stops the siphon action and leaves enough water in boiler to reheat for the next brew. Achieving the siphon point may be a larger volume of water for 1/2 a pot but may work for 3/4ths a pot. The 1/2 way mark may be affected by the brewers "level" while placed on a table or sagging in the middle of a weak table.
* Usually if you want a smaller brew then go with a smaller brewer. Though there is a hot water tap that will give you 2-4 cups of hot water (it gets tepid after that) which you can use for the "Mug" style brew. But it does get messy.ukeboy57
* Final, If you don't mind a little more than 1/2 pot brews then ask your vendor to adjust the machine for you. Though a reminder NOT the double brew in the same pot as it will overflow.
Aloha, ukeboy57
Dec 28, 2017 | Bunn Coffee Makers & Espresso Machines
Water overfill
The A10 has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
PS. Check your using the correct size decanter for this brewer. If it's a 10 cup brewer then make sure all the decanters in the office is also 10 cup. Pouring a 12 cup pot into brewer will have 12 cups of coffee come out (over flowing the 10 cup pot.) Note that not all decanters are made the same size. Other brands may be different. Test by filling a pot with water (from faucet) then pouring directly into pot in question. It should match and not under fill nor over fill.
Apr 04, 2014 | Bunn A10 Coffee Maker
WE HAVE A BUNN VLPF SERIES COFFEE MAKER. WHEN YOU PUSH THE BUTTON TO MAKE A POT OF COFFEE, THE WATER DOESNT STOP AT ONE POT IT MAKES 6-7 BEFORE IT STOPS. IF YOU TURN OFF THE MACHINE WHEN THE DECANTER IS...
Feb 07, 2011 | Bunn VLPF Coffee Maker
No pot or instructions, how much water do you put in the coffee pot?Need a replacement pot for vp17 series. thank you
You should be able to pick up a replacement/new pot at your nearest Restaurant Supply store. Make sure you get a 64 oz./ 1/2 gallon pot.
Before plugging in your brewer, unscrew the sprayhead located just above where the filter basket sits and replace the basket, pour 3 pots of cold water through the opening on the top if the brewer is empty. This brewer has a reservoir that holds about 2 1/2 pots of water at brewing temperature when heated. Make sure you put an empty pot under the filter basket after pouring in the water. Water will flow from the brew basket when the reservoir has reached its capacity. Once water flows you can then plug in and energize your brewer and replace the sprayhead. It will take about 15 to 20 minutes for the brewer to reach brew temp, you will hear the heating stop. Put an empty filter and a dose of coffee (I recommend starting with a heaping measuring cup of drip ground coffee) into the filter basket, lightly shake it level, replace the basket and pour through 1 full pot of COLD water in the top. For best results pour the brewed coffee into a pre-heated thermal server if you plan on holding the coffee for more than 10 minutes or so.
Enjoy!
Jan 04, 2011 | Bunn VP17-1 Coffee Maker
I have a Bunn CWTF15. Water does not fill the coffee pot full anymore. Is there a float that needs to be adjusted? Would descaling help this problem? Thank you.
Sep 12, 2010 | Bunn Automatic Coffee Brewer CWTF15 1
How do i clean my bunn air pot coffee brewer?
Run a pot of half water and half vinegar through the coffee pot and you may need to repeat this process a couple times to get all the calcium buildup cleaned out of the pot. Hope this helps.
Jun 21, 2010 | Bunn Automatic Coffee Brewer CWTF15 1
Stopped spinning and won't drain or do anything noe
hi unplug pull out machine if drain hose is at bottom of machine get bucket put hose in to it water will flow out when full raise hose water will stop repeat untill empty if hose is not at bottom tilt machine so counter top holds it get pot what ever wil fit under the drain fliter unscrew slowly not all the way to let out water once pot is full tigheten repeat untill water is out then open fliter clean look in make sure notthing is wraped around impeller if so take apart and put back same way
Nov 08, 2009 | Zanussi FJS1225W Front Load Washer
MACHINE LEAKS WATER
Turn on machine w/o water or google the company
Jun 02, 2017 | Waring Pro WC1000 Coffee Maker
Do not know how to program fresh start oasis full button over fil
Remove the brew basket and water defuser (sprinkler head) it should come off with a 1\2 turn.
Place your measuring pitcher or empty pot in place.
Turn the main power switch off in back of unit.
Press and hold the Brew(full pot) button.
While holding the Brew(full pot) button turn the main power button in back to on.
Once the red light flashes over the Brew(full pot) button release it, then press it once to start the brew cycle.
Let it flow until desired level in pot or measuring pitcher.
Press the Brew(full pot) button once to Stop.
Press the Brew(full pot) button once again to lock the settings into memory. Memory will store the settings even if machine is unplugged.
Half pot button is automatically set.
Apr 09, 2009 | Oasis FreshStart 80 oz 10-Cup Coffee Maker
Bunn CWTF15 Logo
872 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
