20 Most Recent Westinghouse WRS6R3EW 36" 25.8 Cu. Ft. Side-by-Side Refrigerator w/ Built-In Water & Ice Dispenser &... Questions & Answers
We bought a used but newer model White
Some fridges have an internal fan that sounds like the compressor. If the compressor is running and the fridge is any good the inside will quickly cool and the condenser will become warm. If the outside gets warm but the inside doesn't get cool it is possible the defrost heater is permanently switched on because of a fault. If the compressor is running and nothing is happening the fridge has probably lost it's refrigerant gas. Moving fridges can upset them and it is unwise to switch on straight away - they really need to settle for at least 4 hours. Switching on too soon can damage a lubricant deprived compressor.
10/4/2017 8:56:44 AM • Westinghouse... • Answered on Oct 04, 2017
2answers
Freezer circulating fan not working
Buy a pet cow, and all your problems will be solved!! :)
12/28/2014 12:04:48 AM • Westinghouse... • Answered on Dec 28, 2014
Will not cool refrigerator
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
8/31/2011 12:22:34 AM • Westinghouse... • Answered on Aug 31, 2011
0answers
I have a side by
Insert a pin in the slot under the lower edge of the trim, You should see 2 small holes, that will release the lock tabs, from there you can just pull the frame toward you, Inside you will be able to see the problem.
5/19/2011 8:16:19 PM • Westinghouse... • Answered on May 19, 2011
I have a westinghouse silhouette frost free
THE COMPRESSOR IS NOT WORKING ON YOUR REFRIGERATOR..
2/17/2011 7:16:07 AM • Westinghouse... • Answered on Feb 17, 2011
In the freezer part of the westinghouse
your refrige and freezer are in defrost mode and the sound is water hitting the hearing element as it falls off the evaporator core
9/13/2010 12:33:29 PM • Westinghouse... • Answered on Sep 13, 2010
I have owned a side
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
9/12/2010 12:28:58 AM • Westinghouse... • Answered on Sep 12, 2010
Color change
go to www.applianceart.com, they have many different items and they can make custom sizes and many different colors and designs including stainless steel.
4/11/2010 4:15:15 PM • Westinghouse... • Answered on Apr 11, 2010
Water leaking inside freezer and forming ice in
you need to clean out defrost drain hole maybe have to remove back cover of frezzer i use a turkybaster with hot tap water to force hole opan
2/14/2010 12:03:27 AM • Westinghouse... • Answered on Feb 14, 2010
I want to remove door handle to replace broken fixture.
I think you may have to remove the door gasket, if you look behind the gasket you will see the screws holding it and the inner door liner in place, both should be removed and you will then have access to the handle screws from within the door.
5/27/2009 7:05:12 AM • Westinghouse... • Answered on May 27, 2009
3answers
Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
sounds like a bad thermostat,you can check it with a meter by putting the meter on omes,thermostat in closed position no reading turn thermostat all the way on you should get a reading if not replace,let me know-mike
10/6/2008 12:29:54 AM • Westinghouse... • Answered on Oct 06, 2008
2answers
I cannot get water out of the water dispenser and the icemaker isn't making ice.
is the water freezing up en route? try a full defrost to see. if not a blockage may have occured.
11/26/2007 3:06:08 PM • Westinghouse... • Answered on Nov 26, 2007
Removing internal freezer panel on Westinghouse wtb3400wc
Yes, manufacturers use hidden plastic clips for cheapness. It is likely that it need to go upwards and back to unlatch. There is not much available online except your question and associated questions and answers on similar models. What you could do is remove everything and use a hair dryer on high fan and medium heat to blow warm air behind the panel and melt the ice. https://www.google.com/search?q=westinghouse+wtb3400wc+remove+freezer+back ..
1/21/2024 1:00:50 AM • Westinghouse... • Answered on Jan 21, 2024
What is the gasket compatiable for white Westinghouse refrigerator MRAD17V9GS
Gasket sellers, or you can buy universal gasket material and make one. Another way is to buy by height and width. https://www.google.com/search?q=Westinghouse+MRAD17V9GS+door+gasket ..
12/29/2023 5:19:43 AM • Westinghouse... • Answered on Dec 29, 2023
I have a Westinghouse RJ303k freezer and the defrost alarm light is coming on.
When the room temperature is extremely low a freezer can not disperse its produced heat. Good thing to know anyways.
12/10/2023 12:18:51 PM • Westinghouse... • Answered on Dec 10, 2023
2answers
BJ515V ... my fridge is freexing everythying my freezer is -18.. I have tried my frisge on 3 4 5 & 6 and no change the panel is on the front of the frisge
all freezing? I would suspect the defrost terminator? its realitively inexpensive and easy to fix? located in freezer behind the backwall and attached to the evaporator coils. if thats not it then ur defrost timer is bad? and of course ur heating element itself may have gone bad? all can be checked with a multi meter. u can try a trick to turn on ur defrost timer by placing a small philips screwdriver in the tiny slot under the timer where u see a whole and turn it clockwise slowly till u hear it click just one click not 2 then the defrost will come on and u should hear the fan and compressor go off?
9/29/2023 7:37:52 PM • Westinghouse... • Answered on Sep 29, 2023
Westinghouse WRS6R3EW 36" 25.8 Cu. Ft. Side-by-Side Refrigerator w/ Built-In Water & Ice Dispenser &... Logo
25 questions posted
Top Westinghouse Refrigerators Experts
vince
john h
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Refrigerators
Most Popular Question
  • Refrigerators
