20 Most Recent Norelco Spectra 8867 XL Electric Shaver Questions & Answers
My husband has an older
This shaver type, Spectra, has been discontinued by the manufacturer an is no longer available. There are a few Spectra models available 'factory refurbished', however. You will find one Spectra model, 8880XL, available at shaveroutlet.com. See link below
http://shaveroutlet.com/shavers/norelco-8880xl-spectra-men-s-shaver-factory-refurbished.html
3/3/2011 1:57:01 AM • Norelco Spectra... • Answered on Mar 03, 2011
I'm looking for replacement heads for my 45 to 60 year old Norelco Electric Razor type HP1122. Can they be replaced?
Question edited for clarity. Two questions merged to one. Duplicate question deleted, refresh page to see your question. some Norelco spares are available https://www.google.com/search?q=replacement+heads+for+my+old+Norelco+Electric+Razor+type+HP1122 ..
12/3/2023 7:14:30 AM • Norelco Health &... • Answered on Dec 03, 2023
Can I purchase replacement heads for my old Norelco razor type HP1122?
I see some that are offered on E Bay https://www.ebay.com/itm/404374101537?chn=ps
12/2/2023 6:11:40 PM • Norelco Health &... • Answered on Dec 02, 2023
My Phillips Norelco NT8110/60 NoseTrimmer 1100 does not turn on even new batteries
It is possible that your shaver does not turn on or move because it is dirty. There can be hair or dirt particles stuck inside it, causing the shaving heads to be blocked. To fix this problem, properly clean your shaver. If possible, remove the shaving head and clean your shaver from the inside as well.
10/25/2022 3:03:22 PM • Norelco Health &... • Answered on Oct 25, 2022
3answers
The Norelco Smart clean system wont fill with solution
It's true that Norelco does not sell parts for this unit, but you can buy a exact replacement for the pump motor here:https://www.amazon.com/dp/B0146XUE4I/ref=cm_sw_r_api_i_KGSBKR1BPW349RR3YRSB_0?psc=1.The only difference will be the length of the replacement motor shaft is too long, but this can be modified using a Dremel cut-off tool. Getting to the motor is a bit involved, but it is possible to do so without breaking anything. You'll need a T-8 driver and a small flat screw screw driver Begin by releasing the bottom, remove the fluid cartridge, and turn the unit upside down. Find and remove the (3) T-8 screws along the bottom perimeter. 7ac8779f-b19a-4ae5-9c44-d6e5aaa6f913-z2yn4bmf1m5lm14gqirpgkla-d-3.jpeg Next, use the small flat screwdriver or plastic pry bar to lift the outer case over the upper edge of the rear power supply socket and slide the outer case down. You'll also need to press the cartridge release button to clear the case img_1148-xvzutl3xscw24k454xtszrrg-d-9.jpeg Slip the outer case off the bottom. You'll need to twist it somewhat to clear the base. Now find and unplug the two side wire connectors (purple/white and orange/white wires) and slide the rear power supply connector off of the back of the unit, leaving it connected to the circuit board img_1157-xvzutl3xscw24k454xtszrrg-d-13.jpeg Now find and remove the (4) silver T-8 screws holding the base to the circuit board. Back the screws out only far enough to separate the base from the circuit board, leaving them attached to the black base so as to make it easier to reinstall later 2f19e7ec-78c4-4eef-811a-8147c18638bc-z2yn4bmf1m5lm14gqirpgkla-d-19.jpeg Gently separate the base from the circuit board. You will feel a bit of resistance as a hose separates from the base. Note where it attaches for later reinstallation. Now we need to remove the "legs" to gain access to the bottom of the pump. Place the separated vase upright and compress the springs to lock the legs in closed position. Note the two hooked ends sticking up. You will be using the small flat screwdriver to pry these towards the center. c334ff2f-779d-4345-8958-044196dd4897-z2yn4bmf1m5lm14gqirpgkla-d-21.jpeg Open the "legs" by pressing the side button. Slide the flat screwdriver down the side of the base and use it to pry the hook so you can pull the leg out. You'll have to pull slightly on the bottom while doing this until you feel the hook release, and then you'll move the screwdriver to the second hook on this leg and repeat. Then move to the other leg and do the same. It takes a bit of practice but it'll eventually release. Be gentle. d908e2a0-2fb6-44f9-ad88-008b83da89e0-z2yn4bmf1m5lm14gqirpgkla-d-34.jpeg Separate the leg unit from the rest of the base. Be careful not to tangle or damage the coil springs. Set the legs and springs aside. Inspect the bottom of the pump. Gently pry the bottom cap off of the pump with your fingernails. bdca4e28-03b0-4665-ae70-40eafc34c4e3-z2yn4bmf1m5lm14gqirpgkla-d-41.jpeg Gently pry the impeller off the bottom of the pump motor shaft using a tiny screwdriver. Be careful not to damage the impeller. d2303d22-0aa6-4670-9878-904c9fd799d5-z2yn4bmf1m5lm14gqirpgkla-d-47.jpeg Turn the pump unit over. Use small screwdriver to gently pop loose the pump motor restraint (3 points) dfae5e24-b617-4348-aa45-4a90037df002-z2yn4bmf1m5lm14gqirpgkla-d-59.jpeg Lift the pump motor out of the housing. You can now clean the housing. fbac730d-e7b7-4fb8-b717-5c33f98d4050-z2yn4bmf1m5lm14gqirpgkla-d-67.jpeg Remove the two seals from the impeller end of the motor. You will transfer these to the replacement motor. afc38227-01b2-4134-a31f-459019f1f82a-z2yn4bmf1m5lm14gqirpgkla-d-80.jpegUse soldering iron to remove the wires from the old motor and solder them to the new motor. Use a Dremel tool to shorten the shaft of the replacement motor to match the length of the old motor.Installation is the reverse of removal except I recommend saving reinstallation of the "legs" and springs for last - put everything else together first, including the outer case. Then line up the springs and legs and carefully press them together.
7/26/2022 7:17:52 AM • Norelco Health &... • Answered on Jul 26, 2022
Norelco 5815X shaver battery replacement
Was the polarity correct? Did you leave on to charge for a few hours. If yes to all that, then yes, the board has failed.
1/31/2022 10:50:48 PM • Norelco Health &... • Answered on Jan 31, 2022
Blades for norelco sc 8130 what part number
This model was made about 50 years ago. Blades have not been made for it for 30 years
1/30/2022 9:53:39 PM • Norelco Health &... • Answered on Jan 30, 2022
Where can i get a manual for norelco 495b electric shaver
ASK GOOGLE THE QUESTION
10/13/2021 8:49:59 PM • Norelco Health &... • Answered on Oct 13, 2021
Model 825RX shaver. Can it be used on 230 volts?
yes, model 825RX has dual voltage capability
3/10/2021 2:23:54 PM • Norelco Health &... • Answered on Mar 10, 2021
I am looking to find shaver Phlips brand Norelco
https://www.msn.com/en-us/Lifestyle/rf-buying-guides/best-norelco-shavers-reviews- BEST NORESCO SHAVERS
1/25/2021 6:10:15 AM • Norelco Health &... • Answered on Jan 25, 2021
Model 8140XL Razor. How can I replace motor gear assembly?
The part comes complete as motor and gears.https://philips.encompass.com/model/NOR8140XL..
1/5/2021 6:34:05 PM • Norelco Health &... • Answered on Jan 05, 2021
2answers
Have a norelco curly pkus ,do l put water in the top
If your Norelco has a dry/wet shave feature, get your skin damp and then apply a thin layer of shaving cream, gel or foam. Press the "on/off" button once to turn on the shaver. Run the shaver over your cheeks and jawline in both circular and straight motions, working against the grain, or growth, of the hair. So I wouldn't put water in the top so you do not damage the product.
2/27/2019 11:09:28 AM • Norelco Health &... • Answered on Feb 27, 2019
Philip Norelco 1280xcc how to replace the batteries
https://www.youtube.com/watch?time_continue=36&v=2oAnLpvdYqQ
1/31/2019 5:08:55 PM • Norelco Health &... • Answered on Jan 31, 2019
I need a new battery for my Norelco 905RX Electric shaver
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=Norelco+905RX+Battery Choose my answer as helpful if is the right one
1/31/2019 5:02:16 PM • Norelco Health &... • Answered on Jan 31, 2019
Fully charged norelco razor does not seem to shave at all. Should I be able to see the three heads moving?
Simple answer: If you didn't see the 3 heads moving, you may have overtightened the screws. Literary answer: If you saw three heads moving you might be dead, since the only three-headed beast I know is Cerberus, the guard dog of the Underworld...
10/9/2018 10:17:46 AM • Norelco Health &... • Answered on Oct 09, 2018
Health & Beauty Logo
1 questions posted
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Norelco Health & Beauty
Most Popular Question
husband older
  • Health & Beauty
