SOURCE: red warning light
Here is a link to the owners manual for the HQ7785 Electric Shaver. If
this is the wrong model, your manual may be listed at this site as
well.
http://personalcare.owneriq.net/manuals/mfg/philips/hq7740.html
SOURCE: My 985RX Norelco shaver will charge up to 50
charge your shaver for 4hours again it will solve your problem
SOURCE: Norelco Spectra 8 Model 8894XL: Need a new Razor Head Assembly
It sounds like you need a new "head holder". These often wear out over time and fall apart. You will find a replacement at shaveroutlet.com. See link below.
http://shaveroutlet.com/norelco-philips-spectra-sensotec-head-frame-with-hinge-p-329.html
SOURCE: Norelco 985rx Overheats upon charging..
You should always use the same type batteries that your shaver was designed to be used with. Your shaver was designed for use with NiCd batteries. If you have use NiMH batteries this may be causing the problem you described.
However, I would say that it is more likely that you have some sloppy solder that is bridging something that is not supposed to touch. You should check the battery solder joints on the circuit board and clean up any sloppy solder work that may be there.
SOURCE: Arcitec razor 1050X will not cut whiskers
You are certainly not th first person who hasn't been happy with the Arcitec model. If it never worked well for you from the beginning, there is nothing that will make it work now. It's a shame that you've waited past the 45 day return period.
Your old shaver, 6885XL, was a "Quadra" model. These were a popular model type that is now discontinued. If you still have it, it may be able to be repaired. If you would like to replace it with another Quadr model, you will find one at shaveroutlet.com. See link below
http://shaveroutlet.com/shavers/norelco-7886xl-quadra-action-shaver-factory-refurbished-p-534.html
This model is virtually identical to your 6885XL except that it is a newer version
