Question about Norelco Health & Beauty
Https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=Norelco+905RX+Battery
Choose my answer as helpful if is the right one
Posted on Jan 31, 2019
SOURCE: How to replace battery pack for a Norelco 6885xl electric shaver
The battery pack is soldered to the shaver's circuit board. Yes, it's a poor design in building something that people can't readily service unless they have a soldering gun, ******, and wick, plus patience. However, there are plenty complaints online already, and my shaver won't get fixed by b-tching some more.
There are 2 choices for replacement:
1. Bring or mail it to a service center to have the batteries replaced. The fee usually runs $29.99-$39.99, which includes the battery, parts, labor, lubrating your motor, cleaning the interior, cleaning/stripping the cutters, heads, and trimmer, plus return shipping.
2. To save yourself $26-33 bucks, make sure you know how to solder and have the equipment described above. you can find single NiCad AA with solder tab for $3ea or a pair for about $7.95+. Table the batteries together, solder a single tab across +/- on one side, and solder the others onto their respective tabs in your shaver.
For me, I'd love nothing than to hobby around and do it myself, but with 3 kids, a full-time, job, Wii, and other hobbies, it's easiest to just send it out... some services will guarantee to have it done within 2 days of receipt. You'll just have a lil beard to test it out when you get it back. :-)
Posted on Oct 16, 2008
SOURCE: replacing batteries in a 6705x norelco shaver
To open up your shaver, remove the lotion cover and remove all 5 screws
with a small flat head screwdriver. They have a star head, but also a
flat notch. Since they shaver is water tight, the first time you open
it up it will be difficult, but if you pry off with your screwdriver it
should pop off.
Towards the head of the shaver the batteries are soldered to the
circuit board. Pull the tail end of the batteries out of the plastic
holder and cut them at the top end as close to the batteries as you
can, or CAREFULLY bend it back and forth to snap the metal. Dispose of
the batteries responsibly as you would any batteries.
Hope it helps you.
Posted on Jan 07, 2009
SOURCE: Norelco shaver service centre in India
i am based at hyderabad india and wish to get my norelco shavers modelno4852XL and 7864 repaired is there any sevice centre in hyderabad andhrapradesh india
please email me on [email protected]
Posted on Apr 18, 2009
SOURCE: can i use shaving cream with a norelco electric
According to the Phillips website, it is NOT a waterproof shaver, therefore it is not advisable to use any liquids prior to or during shaving.
However, as a hairdresser and having experience with shaving men for many years, you can use the tried tested and true method of either shaving AFTER you get out of the shower so that your hairs on your face are softer from being in the moisture, or if you are not planning on having a shower, you can just use a hot face cloth on your face for a few minutes before you shave. This will soften the bristly hairs on your face and make it easier to shave.
I hope this helps. Please remember to rate my help. I would greatly appreciate it!
Posted on Apr 26, 2009
SOURCE: how to replace batteriers in norelco quadra electric shaver
The rechargeable batteries are solder into the circuit board of the electric shaver. You'll have to use a soldering iron to de-solder the terminals/tabs from the PCB (printed circuit board) in order to get them out.
Then you'll need new replacement rechargeable batteries to solder back into the shaver.
You can get teh correct replacement batteries from Electric Shaver Service in Lincoln, Nebraska (if you're in the US or Canada). They even do service and repair work in about a week, if you want to have them fix your shaver for you.
Here's a link to the battery page with your shaver model's rechargeable batteries for about $15.00 (plus s&h)
http://www.electricshaverstore.com/get_item_13810334_norelco-13810334-electric-shaver-battery-set.htm
Hope you find this Very Helpful and best regards!
Posted on Aug 22, 2009
